Rubber Queen Foldin...
[Closed] Rubber Queen Folding vs Mountain King II Folding
 hope
[#3792926]
Hi all any advice on the above tyres
And also is Black Chilli really worth paying twice the price?
Any advice would be appreciated!
Thanks!
Posted : 20/03/2012 8:05 pm
 mboy
Yes/no/maybe
I wouldn't run non-Black Chilli conti's if I was paid to though! They're bloody awful...
I did think the Black Chilli compound really was just a load of marketing guff, and that no tyre can be worth almost £50, but the Black Chilli RQ's really are a bloody good tyre, and probably my current fave. Whether or not it's worth £50 per tyre is a whole other argument, but they are bloody good.
So in essence, they're not worth twice the price, they're worth an infinite amount more IMO.
Posted : 20/03/2012 8:08 pm
2.4 rubber queen (black chilli) is an awesome tyre.
Posted : 20/03/2012 8:13 pm
 hope
I can't clear 2.4 on my frame.
I wondered if anyone uses non black chili?
Posted : 20/03/2012 8:36 pm
 hope
By the way. I have been offered the above 2 at the exact same price and the black chili is exactly double
Posted : 20/03/2012 8:39 pm
I have a RQ (wire bead)2.4 on the front and it is uber-grippy!
Posted : 20/03/2012 8:43 pm
I'd get some of the 700g-800g 2.35 or 2.5 single ply High Rollers in that case, as they'll grip better. The non-black chilli tyres blow.
Posted : 20/03/2012 8:44 pm
Spesh Eskar2 2.3s are on a par with the RQ Black Chilli. Much cheaper too.
Posted : 20/03/2012 8:54 pm
 hope
This is so confusing haha
Posted : 20/03/2012 10:42 pm
Got a black chilli RQ 2.2 delivered from Germany last week for 35 quid. Great tyre and well worth the money. My Core came with stock MK's and they weren't so good. I would stay clear of the conti's unless they're black chilli.
Posted : 20/03/2012 10:44 pm
Slightly off topic, i run 2.3 black chilli barons and they are amazing, i dont understand how they are so fast but they are! i much prefer them to the rubber queens,
Posted : 20/03/2012 10:48 pm
Just got a pair of Mountain King 2's 2.2 delivered today. Mounted them onto some Stans 355 rims (very easily may I add) but they are very narrow. They only measure just over 2" wide 🙁
I'm sure Rubber Queens are MUCH bigger.
Posted : 20/03/2012 11:01 pm
 hope
It would explain the massive weight difference,
Did you ride on the Mountain King 2s?
Posted : 20/03/2012 11:16 pm
The RQs come up huge by the way. My friend runs the 2.2s and they aren't far off the size om my 2.4 advantages. Never seen a 2.4 rubber queen but I'm guessing they will be massive. Another confusing thing is that the 2.2 RQs came up bigger than another mate's 2.4 mountain king 2s. Weird...
Posted : 20/03/2012 11:42 pm
 hope
Were you running non black chills?
Posted : 20/03/2012 11:49 pm
+1 get them from germany
+1 RQ chilli flavour rocks 🙂
Posted : 20/03/2012 11:57 pm
hope - Member
It's a complicated question 🙂 On the one hand, they're too expensive- Conti need their posh rubber to make a tyre that works competently, with most of their range it's hard to really see what you're paying for.
But on the other, I've never used a non-black-chili tyre that wasn't pish. So compared to other Contis, yes it's worth it, compared to other manufacturers no it's not.
Honourable exception goes to the Baron, which is a[i] fantastic[/i] tyre, I've not found anything else to directly compete. But my Rubber Queens came off and were replaced with £22 Nevegals, which are a little slower but almost as big, lighter, and miles grippier.
Posted : 20/03/2012 11:59 pm
not yet, but will be doing tonight
Posted : 21/03/2012 7:30 am
Tried the RQ's a while back (BC version, 2.2). Fast Tyre and definitely grippy BUT... I got a puncture first time out and managed to tear the sidewall a few months later. I'm not exactly a hardcore rider, I get very few punctures where I usually ride so the fact that the RQ cost so much made these things that much more off putting. I'd only go back if I could get them very cheaply.
Jedi has ridden both I believe so maybe he'll do a compare and contrast in the next video blog.
Posted : 21/03/2012 9:02 am
My 2.4 BC Queens are pretty grippy things, not as grippy as Maxxis super tackies but the Queens are a better all-rounder that can be used front and rear without affecting the rolling resistance too much……the non-BC version that I’ve also been using is nowhere near as good, especially in damp or wet conditions, and even in the dry it struggles to find grip on roots and flat rock.
Posted : 21/03/2012 9:09 am
I'm having a bit of a Conti Black Chilli fest at the moment. Last couple of years has seen me change my main two bikes over to various big Conti tyres. I started running 2.4 BC Rubber Queens and loved them. I was running the non UST's tubeless but I found the rear sidewall a bit delicate so I went with a UST on the back. There was not much clearance so for the winter I went for Baron's front and back which I also like a lot. They come up much smaller than the 2.4 RQ, almost the same size as the 2.2 BC RQ which I run on my hardtail (again non UST but tubeless). The 2.2 RQ is much lighter than the Baron and the 2.4 RQ which are about the same - the UST is much heavier.
I've ripped a couple of sidewalls which is a pain in the arse and they can take a while and a lot of sealant to run tubeless, but I love the level of grip and feel from them all. I like them as they are all so light, big and grippy.
The wierd thing is the tread is grippy and yet it doesn't seem to wear... all the Conti's I have killed have gone at the sidewall or the bead. I've patched a few of the sidewalls I've cut and they hold up fine... but I wish they didn't cut so easily. I kind of wish I hadn't tried them as I've become a bit of an addict to the performance... but the issues of sealing and damage have had me swearing at them in the garage and on the trail. Who knows... if I ran Maxis/Michelin/etc I would probably be singing their praises as I would be well happy with them as well.
Posted : 21/03/2012 9:16 am
I use BC rubber queens and Barons and they're very good tyres. Killed a 2.2 RQ at the weekend. It wad a year and a half old, had been run on the rear, covered a fair old mileage and survived a week in the alps. The tread was ok but it was the side walls that went. I'll be replacing it with another.
Posted : 21/03/2012 10:57 am
I've got 2.4 BC Rubber Queens on the front and I am amazed how grippy it is, really love it. I've recently bought a 2.2 BC UST one (ebay only £25) for the rear. Haven't tried the non black chillies and I would be interested to see if there's a difference.
Posted : 21/03/2012 11:14 am
Northwind - Member
Honourable exception goes to the Baron, which is a fantastic tyre, I've not found anything else to directly compete. But my Rubber Queens came off and were replaced with £22 Nevegals, which are a little slower but almost as big, lighter, and miles grippier.
Is that the 'sticke' or the normal flavour ?
Posted : 21/03/2012 11:51 am
The non black chillies are absolutely Godawful ime they are more suitable for putting on the side of a canal barge
Posted : 21/03/2012 11:59 am
 scud
I'v got a set of black chill 2.2 R.Q's and I think they are fantastic, but i have tried to set them up tubeless with Stans and found that the sidewalls were almost porous, has anyone got any tips on getting them done tubeless?
Posted : 21/03/2012 12:28 pm
I've got about 3 rides on my BC UST rubber queens now (2.4 front, 2.2 back), the 2.4 is really good on the front, plenty of grip, the tyres also roll suprisingly fast, but anything probably would coming from Nevegals.
I've been riding somewhere new recently, and the ground is still a little soft (damp) and quite loamy, the rear tyre doesn't offer as much grip as stuff I have used before; Nevegal, Excavator, Ignitor. But that may have sometihng to do with it being loaded with mud and me not being able to get up enough speed to clear it.
I'd definitely get one for the front again but would want something a bit spikier for the rear, maybe a baron? Also, the 2.4 isn't that big, isn't only marginally wider than a 2.35 nevegal, the volume is huge though and with low pressure (I'm 28ish front, 26ish psi rear) the grip on roots and rocks is really good.
Posted : 21/03/2012 12:32 pm
i'm also struggling to get my 2.2 RQ black chilli to stay up tubeless - the sidewalls are just really porous. Seems like a really round tyre - the sidewalls seem to stick out more than the tread. Not expecting to like it but having spent £40 on it I guess i had better give it a try.
Posted : 21/03/2012 1:04 pm
Trick for getting the non UST RQ and Baron tyres to seal is to use loads of sealant... about twice what you think is reasonable.
Here is what I do... Do it once with what you think is the right amount, for the next week keep topping it up with air hoping it seals, after a week give up and slurge the same in again... bingo it stays up.
I did have one massive hole on a secondhand tyre so I stuck a patch on it, and I've also patched cut sidewalls when required.
Another trick is to wipe the inside of the tyre with meths to remove whatever greasy stuff is left over from the manufacturing process. I read it on here and it does seem to help.
Posted : 21/03/2012 1:10 pm
I don't use more sealant for Contis, I just use more patience... Eventually they all seal up but it can take a long time. Doesn't matter too much as long as the pressure stays stable-ish for the length of a ride though.
Posted : 21/03/2012 8:30 pm
 hope
Talk about thread spoiling haha, feel free to digress from the topic. Lol. 😆
Posted : 21/03/2012 8:36 pm
Hope, you don't have an email address but i'm sticking a 2.4 Rubber Queen Black Chilli protection wall used for 4 rides on the front wheel in the classifieds tonight for £35 posted if you're interested?
Posted : 22/03/2012 1:06 pm
I have both a RQ2.2 and MK2 2.2 - they look almost exactly the same size to me. havent got the Mk2 on a rim yet as I'm still struggling to get the RQ to stay up. Bit underwhelmed really as i was expecting the RQ to be much bigger after all the comments on here.
Posted : 22/03/2012 4:23 pm
 hope
Wozza, I won't get the 2.4 on I don't think.
Posted : 22/03/2012 5:06 pm
 jedi
the tread pattern is simular and i reckon my 2.4 mk's are the same size as my daughter 2.2 rq's! so far so good. no issues
Posted : 22/03/2012 6:05 pm
Care to share where from?
Posted : 22/03/2012 8:55 pm
www.bike-discount.de/
Site is down at the moment but think it was 35.90 euros for tyre and about 5 euros delivery.
Posted : 22/03/2012 11:37 pm
Thanks muchly.
I already have a BC RQ on't front, it's been grand. My old high roller is starting to loose it's side knobs though, time for a new 'un.
Posted : 23/03/2012 1:28 am
CONTINENTAL RUBBER QUEEN BLACK CHILLI - 26 X 2.4 INCHES bought from Velo Ecosse [b]£34.95 delivered [/b]fantastic tyre so far.
Posted : 23/03/2012 7:56 am
CONTINENTAL RUBBER QUEEN BLACK CHILLI - 26 X 2.4 INCHES bought from Velo Ecosse £34.95 delivered fantastic tyre so far.
http://www.veloecosse.com/productdetails.asp?productid=16494
You did well. According to site there now £44.95.
Posted : 23/03/2012 9:41 am
sorry try dales bike doctor too, he had some good prices last week.
Posted : 23/03/2012 10:30 am
I tried the MK 2's 2.2's on Wed round Farleton Knott.
Not really impressed TBH. They are very small with little volume and seems to 'ping' off the rocks and didn't grip too well either.
I ran them at 22psi front and 24psi rear (same as a run my HR and swampthings). The did roll better then then the 42a/60a HR combo, but that is to be expected.
It was however full of 'sticky' mud, so clogging may have had something to do with the lack of grip as well.
going to try a pair of 2.25" Ardents this weekend to compare.
Posted : 23/03/2012 11:07 am
I've got some MK 2.2's Folding Black Chilli Protection They are light, roll fast but do not grip too well esp on wet rock. Not used them much as its not usually dry round here.
Posted : 23/03/2012 11:17 am
 hope
Thanks, there has been some great advice on here.
I pulled the trigger on the Black Chili 2.2 last night and look forward to trying them!
Nearly went for X-Kings but decided against it.
Posted : 23/03/2012 11:58 am
That's what I run Eskar on the rear MK ll on the front, I also got my MK from Tweeks with 20% off for £35 Si well happy, Also have a friend going to Hamburg for 5 weeks today, will as him to see how much they are out there if there a lot cheaper he could get some more for me.
Posted : 25/03/2012 9:29 am
