Hi – need quick answer to what is probably a dumbass question.
Bear with me:
I currently have a 203mm XT 6 bolt rotor up front (RS Revelation post mount using a 203mm caliper adaptor) on a DT Swiss centerlock hub using a DT Swiss adaptor. Out back I have a 185mm XTR centerlock rotor on an XT centerlock hub using a 185mm caliper adaptor.
I am buying a Hope 6 bolt rear wheel as my current rear needs replacing.
Can I use my front 203mm 6 bolt front rotor with the 203mm caliper adaptor on the back – then put the 185mm centerlock rotor on the front using the 185mm caliper adaptor?
In theory I should be able to – means the front rotor will be slightly (18mm) smaller than the back.
I need a quick ‘yes you can do it’ as picking up wheel after work!
Cheers 🙂
