I've managed to lose the barrel nut which holds the actual lever on to the fitting - essentially, part of the hinge mechanism. The Rockshox spare parts catalogue doesn't list this part separately - only the whole assembly. Anyone else lost the nut and found a suitable alternative?
Bike Forum
Rockshox Pushloc Lever parts
Posted 8 months ago #
I broke my pushloc in an off, and switched to poploc as cheaper lever etc. I should have the nut on the old one if you're interested.I'll look in morning and get back to you.
Posted 8 months ago # -
OK found it. Is it the barrel that goes through the base of the black bit that holds the black bit to the silver bit that mounts on the bars?
If so you're more than welcome to it.
Let me know.
Just found this post thread while searching for a pushloc part myself.....the actual bolt to clamp it to the bar. Shifted my brakes and gears + pushloc inboard on the bar a bit and because the pushloc uses a smaller fitting alan key, forgot to tighten it......result was pushloc flying off bar 10 minutes into ride...doh! a trail fix with insulation tape salvaged the ride but now need a new one. Realise your bolt might have broken as part of the off but hope you don't mind me asking if you still have it??
Posted 5 months ago # -
Is pushloc the alloy clamp or black plastic one?
If it's the alloy version I have a broken one in the garage (just the lever that is broken)Posted 5 months ago # -
Hi Phil...it is indeed the alloy one. What can I trade you for the bolt? I recon a bacon Sarnie is good currency if you are anywhere near Cannock Chase?!
Sounds a fair deal - only snag is I'm not back in the UK till Wednesday, but if you email me your address I'll send to to you as soon as I get back.
Fabulous....dropping you an email now
Big thanks to phil56....poplock now fully operational thanks to spare screw....very much appreciated.
Now if only someone had a spare Blur LT2 frame they were giving away........
Reply
You must log in to post.
