Hi All,
I have some 95 to 140mm Coil Pike 409 forks but the travel has seized, zero travel with a horrid clunking sound over bumps. U-turn still works but not going to full range. No leaks and no major scratches.
Looking around the web and having asked a mechanic at Haldon Forest it is apparently a common fault with the motion control and he quoted over £100 and 2 days work (prob for ordering parts)
I am skint with young mouths to feed so looking to avoid TFTuned and LBS prices by home servicing so need some advice regarding tools and oils.
Looks like I need 15 wt and 5 wt oil, ratchet with 24mm deep socket,snap ring pliers and a Motion control service kit off the bay.
Any advice on what to look out for would be very welcome.
