Rock N Roll Extreme...
[Closed] Rock N Roll Extreme lube
[#669447]
Anyone used/used it - what do you think? Am using Motorex dry atm and its good for 15 or so miles then squeaks like buggery!
Does this dry or stay wet?
Posted : 29/06/2009 9:32 am
Like it a lot, does not pick upcrap off the trail, a good soaking lasts a good while... certainly longer than 15 mins....
Posted : 29/06/2009 9:39 am
Thinking of buying the liter bottle and putting the chain in for a few minutes to soak it, then letting it drip back into the bottle using a funnel!!
Posted : 29/06/2009 9:49 am
I've used it for years
You need to follow the instructions if you want it to work properly
After applying it & spinning the drivetrain around a bit, you wipe the outside of the chain clean of everything so it's effectively dry to the touch
Lasts well - very wet weather & it could do with re-applying after about 4hrs otherwise it'll last all day & maybe longer, I re-apply after every ride
Posted : 29/06/2009 9:54 am
RnR works really well, make sure you start with a spotless chain though, otherwise you waste a lot of the new lube cleaning off the old gunk. (It'll make sense when you try it!)
Chain cleaning tip: chain in a bucket, good squirt of degreaser (Fenwicks or whatever), half a kettle of boiling water. Swirl it around for a bit, leave for 15 mins, rinse chain in more hot water. Voila!
Posted : 29/06/2009 9:57 am
Buy 2 Rob, and send 1 to me..
And I'll post you the remote lever..
M'k?
Posted : 29/06/2009 10:10 am
Agree Rock n Roll Extreme is good stuff bit of a faff cleaning the chain all the time I put the chain in a tupperware container with some Fenwicks plus boiling water uses less Fenwicks.
I made the mistake of ordering a new bottle of R n R whilst I was pished. Ordered a bottle of Purple Extreme instead of Rock n Roll Extreme. Jeez the Purple Extreme stuff is useless its okay as a dry conditions lube for my road bike but show it a bit of rain or mud and its worse than useless. Squeaky squeak squeak for 20 miles nearly threw bike in a ditch and rang for a taxi.
Teetosugars - Member
M'k?
MK?
Posted : 29/06/2009 10:19 am
i use R&R on all my bikes - both mtbs and commuter. it's really good, miles better than anything else i've used.
Posted : 29/06/2009 10:27 am
whats the Rock n roll gold one like, or is it just a dryer weather version of the extreme?
Posted : 29/06/2009 10:31 am
R&R is good stuff. It gives the smoothest quietest drivetrain of any lube I've tried. Does wash out though in prolonged (like a day) heavy rain.
Posted : 29/06/2009 10:34 am
FWIW R'n'R gets my endorsement. I hate chains covered in oil/smeg/grot etc. Mine's always shining 🙂
Posted : 29/06/2009 11:57 am
Gone back to finishline wet lube because I've run out of R&R blue. My god it's mucky, works good in the wet, but R is just as good & cleaner.
Posted : 29/06/2009 12:32 pm
how many applications do you get out of a 4oz bottle ? ...thinking about ordering some after many yrs with finish line green
Posted : 29/06/2009 1:31 pm
 AB
I use White Lightening and find that a good lube.
Posted : 29/06/2009 1:38 pm
AB - Member
Used to use it in my Calderdale days, always resulted in a squeaking chain after about two hours. Might be better if it's dryer under your tyres.
Posted : 29/06/2009 1:47 pm
Hat to disagree with everyone, but I've found the Rock n Roll stuff next to useless when it's wet in the Peak. Lasts about an hour if that before the grit and wet just scours it off the chain. The new Squirt stuff is supposed to be good, someone bunged me a bottle last week, will degrease the chain, stick it on and see how it does.
Posted : 29/06/2009 2:01 pm
I've found R&R to be excellent, just make sure the chain is throughly degreased and clean before initial application. After that, in summer I just re-apply to lean and lunricate, in winter a quick wash and scrub with Fenwicks on the bike, dry, then re-apply R&R.
As to lasting for only an hour when wet in the Peak district, surprised anything lasts that long in grinding paste that wrecks metal components.
Posted : 29/06/2009 2:10 pm
