Viewing 7 posts - 1 through 7 (of 7 total)
  • Road brake pads
  • soma_rich
    How do I know which size to get for my B’twin Triban 5? 55mm/52mm/50mm ?
    rootes1
    where did you get those size options from?
    Anyhow if you have standard type road caliper brake they should have pads with a replaceable insert..
    if so 99% it will be shimano pattern. so get these:
    http://www.wiggle.co.uk/swissstop-flash-pro-green-high-performance-pads/
    expensive, but they last ages, work well in the wet and dry, stop that black dust and are kind to you rims.
    soma_rich
    On this page I can see 3 or 4 different sizes. They are just standard replaceable inserts..
    http://www.chainreactioncycles.com/Categories.aspx?CategoryID=556
    rootes1
    Hi Rich, no link above?
    soma_rich
    oops soz its there now…
    rootes1
    ok i see..
    either way get the shimano swisstops
    bound to fit, they fitted my road bike and my brompton
    atlaz
    swissstops for me. I have the dual compound ones
The topic ‘Road brake pads’ is closed to new replies.
