road bike gearing -...
[Closed] road bike gearing - a question
[#2590575]
I am sorting out a road bike for a mate who is doing the dartmoor classic, and there is a few hills out there, and his legs need a bit of help...
his bike is currently running a 39/52 and 12/23 setup.
question is: what would be the better solution to allow him to winch up the hills if he blows up? (irrespective of price)
compact chainset 34/50 or a wider spread on the back say 11-27?
both give roughly the same gain ratios on sheldon browns website...
any problems with either idea?
Posted : 23/03/2011 10:44 am
If he's currently got an 11t difference on the back, will the rear derailleur cope with a 16t difference ?
Aren't short cage road mechs a bit limited ?
Posted : 23/03/2011 10:47 am
 cp
how about doing both compact and 11-27 for full winchability?!
[edit] - my road bike originally came with 12-27 & 34-50 compact with a medium cage 105 rear mech.
Posted : 23/03/2011 10:49 am
A normal rear mech should handle a compact and 12-27. Gearing sounds right - there's some grim climbs down there and he'll need that low gear.
Posted : 23/03/2011 10:50 am
I've ridden this one. It's lumpy, but an ace day out..!
I think I rode 39/27 but it was hard work on some of the climbs.
TBH, I'd go for compact and a 25 or 27 at the back, and have a huge range of gears.
Posted : 23/03/2011 10:51 am
Chainrings last longer than cassettes but buying a hainset will cost more. If you are replacing a worn cassette you'll need a new chain.
Road mechs should cope at 27T Shirley?
tell me about it... proper face melter's
thats what I was thinking...
Posted : 23/03/2011 10:52 am
FWIW my road rr mech copes with 13-25 and a 30/42/52 triple OK.
Triples may be no more exp than compacts - but way less gay.
Posted : 23/03/2011 10:56 am
I had a 39/52 a couple of years ago when I did the Dragon Ride - the most cost-effective way for me to get some winching gears was an old mtb rear mech and a 11-32 cassette. Worth considering if you've got the bits around.
Posted : 23/03/2011 10:59 am
triple all the way for me, but he would been chainset, mech and shifter... gets a tad expensive.
not a bad shout
Posted : 23/03/2011 11:04 am
