At the advice of STW Blur LTc owners I got myself a coil to switch with my Monarch 4.2 when the going gets tough i.e. yearly Sierra Nevada holiday / Scottish big hills and techy lakes rides.
So i've fitted a lighter weight spring (400 lbs, i'm 13st kitted up), tightened the ring thing to stop the spring banging about (do i need to consider anything else with the pre load?), measured sag, put pro pedal into its lowest setting (vpp suspension apparently doesn't need it!) and rode up and down the road jumping kerbs etc.
So, is what I have done above correct and is there anything else I need to be doing before packing my van and heading up to scotland?
Go ride,see how it feels. You can add about 3 turns of preload maximum if the spring is too soft. You'll know if you need a different spring after your trip.
There are a number of spring calculators which will give you a rough idea, you have probably used one already?
I did, TFT stated around 350lbs for my weight. I got around 25% sag with the 450 and just on 30% with the 400lbs. Which i think is about right.
Don't pick up a ti spring, you will want one!
Yeah i know! I thought id get a couple of steel springs to see if I like 'coil', if it doesnt feel too different to the air shock ill prob just sell it. Im hoping otherwise though 8)
