riding steps, what&...
[Closed] riding steps, what's the best technique for these?
[#2516306]
sharp turn, uneven heights and distance apart and steeper than the picture suggests, how would you tackle them (it'll be on a rigid or 100mm front sus bike, so no "6/8" travel what steps??" advice please)
[url= http://farm6.static.flickr.com/5180/5484579707_b845e8e84e_z.jp g" target="_blank">http://farm6.static.flickr.com/5180/5484579707_b845e8e84e_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/rocketdog/5484579707/ ]the next challenge[/url] by [url= http://www.flickr.com/people/rocketdog/ ]rOcKeTdOgUk[/url], on Flickr
Posted : 28/02/2011 9:52 pm
i use the hang on and hope technique , of course i fall off a lot
Posted : 28/02/2011 9:55 pm
straight down no front brake,cut the inside line on the 's' bend so the bumps on the corner dont catch you out, lean back and feel your sherriffs badge gripping the saddle baby!!!!!!! Good Luck we want to see a vid!
Get off and walk.
Posted : 28/02/2011 9:57 pm
 jedi
left side til turn then turn as little as you need to make the bend 🙂 heals down, wrists dipppped and enjoy it
bike over the shoulder and walk technique
Posted : 28/02/2011 9:58 pm
Seat down, straight down to the first corner, lock up the back till you stop. Trackstand bounce the front round, release, repeat.
Or take that path on the right...
Looks you can air the lot, rear wheel down on the inside just before the last step, put the front down just after, setting you up nicely for the corner.
Or what?
Posted : 28/02/2011 10:00 pm
on the right of the first turn, the gradient is significantly steeper, it doesn't show on the pic, so straight down isn't really that easy, the exit is extreme left from the last step too
Posted : 28/02/2011 10:01 pm
Ignore that they're steps, they're just bumps ride like you would a rocky descent.
In SdBs case get off and walk. 😛
Posted : 28/02/2011 10:02 pm
Actually, I'd follow the curve of them with the front the to outside, nice and easy, fairly slowly.
But not knowing what they actually look like, I might well take the approach of looking at them, ride up to them a couple of times, chicken out and tell myself I'd get them next time...
Posted : 28/02/2011 10:03 pm
One step at a time.
Boom-tish.
Posted : 28/02/2011 10:06 pm
Slowly, they don't look that bad.................
There's a set just outside Pangbourne that's probably as steep, but near enough straight, as long as you keep the wheels rolling its fine, the real puckering moment is if you pick up speed and end up locking a wheel trying to control it. Either let off the brakes and try and ride it out with even more speed, or keep trying to slow down and hope the whole bike doesn't go rubber side up!
If it were me I'd give Jedi's description a try (but keep right to start surely?) then when that doesn't work, straight down the first bit and cut the corners 🙂
Posted : 28/02/2011 10:07 pm
I think you'd need to pedal [i]really really[/i] hard to get up those
Posted : 28/02/2011 10:08 pm
sit up straight.. death grip.. eyes closed.. stiff upper lip..
Posted : 28/02/2011 10:11 pm
Just wheelie all the way down, then pull a massive skid at the bottom.
Posted : 28/02/2011 10:12 pm
Pick a dry day for a start if the edge of the step is wood.....
Posted : 28/02/2011 10:17 pm
they are all wood 🙂
Posted : 28/02/2011 10:19 pm
Carefully
Posted : 28/02/2011 10:21 pm
just turn right at the top and head for the direct route through the trees.
You'll crash faster that way - no point in delaying the inevitable and you might actually make it.
Posted : 28/02/2011 10:32 pm
 Keva
I'd probably ride on the dirt to the left hand side and then ride the last few steps at the end, possibly cutting across over to the dirt on the right hand side, thus avoiding most of the steps, if that would be possible.
Kev
Posted : 28/02/2011 10:36 pm
I actually find it easier riding techi steps in the dark. 🙂
That way you cant see too much ahead and concentrate on the ones just in front.
Posted : 28/02/2011 10:37 pm
 Pook
Where's that?
Posted : 28/02/2011 10:41 pm
steps down from the Aquaduct, NW Alps
Posted : 28/02/2011 10:44 pm
for a first attempt i would hit them about 30mph clearing the 1st five steps , then a tail spin with triple pike round the right hander finishing off with a rolling endo to finish.
building up to more extravagant decents thereafter
Think I would be heading for an inside line on the right hander.... keeping central on the upper ones as the gravel goes right to the lip, making them flatter in front of the wood edge.
Am I taking this too seriously...?
Just fit Conti Vert Pro's, think about doing this on a wet day but save yourself all the trouble and pain by going straight to hospital A & E.....
Posted : 28/02/2011 11:23 pm
if I'm honest, I wouldn't ride them as even if you don't grab the front brake, the front wheel is likely to tuck under and you're on your face/ back/ arse onto wooden steps and a world of ouch.
ride the dirt round the edge on your way to something [s]more[/s] fun to ride.
Posted : 01/03/2011 12:21 am
 wors
Put flats on.
Posted : 01/03/2011 12:24 am
I'm sure that I would wimp out. Looks fine in reality if I've got my good head on. That right hander does look tricky though. Difficult to see a "nice" line to get in position for that.
Tricky.
Posted : 01/03/2011 12:37 am
 Pogo
Drop yer seat first, so if you have to bail you don't catch yer nads and just roll down em nice and steady with a fair bit of rear brake and butt clenching. Second time down you might not do quite as much butt clenching.
29er or trainer wheels?
No comment *see my other thread*
Posted : 01/03/2011 12:41 am
they look really easy if you just get your weight over the back wheel and drag the back brake?
take it easy and don't tense up
Posted : 01/03/2011 12:44 am
ride up nice and fast, compress the front fork as your approach the first step and as the fork rebounds "pump" the bike into the air, whilst soaring through the air like the glorious eagle your dad said you'd never grow up to be, grab a big defiant fistful of front brake, shift your weight forward over the front wheel and scream "I'M KING OF THE WORLD!!!" as you land.
Posted : 01/03/2011 8:15 am
did you eat cheese before bed Phil?
big wheels, ladies love a set of big'uns
Posted : 01/03/2011 9:18 am
Pump them: for added comfort and control. I find it helps
Posted : 01/03/2011 9:20 am
no cheese before bed... no cheese since... ummmm.... wednesday last week?
i did however sprinkle some extra crack on my morning frosties.
Posted : 01/03/2011 9:22 am
Ride up to the first one and change your mind at the last minute. Topple off sideways. (Funnier if clipped in)
Posted : 01/03/2011 9:23 am
Get your spade out (you do carry one of those in your backpack?) and flatten them out.
Posted : 01/03/2011 9:40 am
To be honest, that look scarily steep (when trying to ride steps) in your photo, and photo tend to flatten out decent badly.
My technic would be, roll in gently.. falling off and sliding down the rest...
Posted : 01/03/2011 9:56 am
Has anyone suggested not bothering with the corners and just straight lining it?
Like this?:
[url= http://farm6.static.flickr.com/5217/5487925209_dd2602db92_o.jp g" target="_blank">http://farm6.static.flickr.com/5217/5487925209_dd2602db92_o.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/peter_atkin/5487925209/ ]5484579707_b845e8e84e_z[/url] by [url= http://www.flickr.com/people/peter_atkin/ ]PeterPoddy[/url], on Flickr
Posted : 01/03/2011 10:05 am
 D0NK
I've no doubt they are steeper than they look. I'd say go slowly but if there's a big lip on the wooden edges it'll throw a spanner in the works and increase chance of stall/fall over.
With twisty turny steps like that I'd either go wide round the far side of the corners or straightline the steep apex. So either keep left till the sharp righthander and take the middle of the trail there or start right and zig zag across the trail cutting across the apex of the corners.
green or red
EDIT but yeah, if you don't mind going off piste Poddys line is better.
Posted : 01/03/2011 10:10 am
 jedi
i tried to draw a line to show evryone and cant get the marker pen off my screen 🙂
Posted : 01/03/2011 10:11 am
probably be using this bike....maybe so i think straight line might not be best
[url= http://farm6.static.flickr.com/5058/5476177825_01a031bb94.jp g" target="_blank">http://farm6.static.flickr.com/5058/5476177825_01a031bb94.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/rocketdog/5476177825/ ]steps[/url] by [url= http://www.flickr.com/people/rocketdog/ ]rOcKeTdOgUk[/url], on Flickr
this is a very cool thread (even if i did start it) i was expecting a **** take as i'm having trouble riding it, but some very good tips here
Posted : 01/03/2011 10:20 am
Straightlining/cutting corners kinda misses the point IMO.
Drop yer saddle, steady speed - fast enough not to stall, not so fast that your out of control - and then go roughly apex to apex all the way down. For the most part the steps look quite widely spaced so there's braking space between them.
Posted : 01/03/2011 10:24 am
Page 1 / 3
