so my month old brand new reverb, which has worked flawlessly since day one, suddenly decided to lose its pressure today out of the blue…
ive always lowered the seat in the car (so it fits in car better) and its always been fine….
today i took it out of the car, pressed the button and it went up fine….got ready and sat on bike to start ride and it squished down about 10mm or so without pushing the lever….i then pushed the lever and pressed the seat post down and it went to the bottom fine…then went to raise it again and it stopped half way 🙁
i then remembered some people on about the air pressure on various threads on here and thought it was worth a punt…
it had about 40-50 psi in, and it pumped up fine upto the 250 psi mark…maybe a bit less once id taken the valve out…
i didnt expect it to work, but low and behold it was perfect! it worked instantly, and if anything the return speed on fastest setting seemed a hell of a lot quicker!
so whats happened then? loco tuning sent it out working fine, and my lbs (Which is great) bled it and shortened the hose…guessing between those two they would have checked the pressure, certainly si at loco would have done anyways
so is it buggered if its suddenly stopped working? or was it just a case of the pressure has lost a bit over the month? im hoping it will obviously stay ok now ive pumped it back up to 250?
