Viewing 9 posts - 1 through 9 (of 9 total)
  • removing decals
  • jonnyrockymountain
    Got some new decals, whats the best thing to use to remove old ones?
    pickle
    Not sure on your frame but on my old BMX frames i just pull them off and use WD40 to clean off the old sticky residue
    jonnyrockymountain
    it’s a ti frame, and they don’t want to be pulled off?
    dashed
    Warm them with a hairdryer, remove any sticky residue with brake cleaner. Never tried brake cleaner on Ti frame but WD40 would work but you’d then need to degrease before applying new ones.
    aP
    Razor blade.
    scotroutes
    Acetone (nail varnish remover) will soften them enough that they can be rubbed off with a cloth.
    zangolin
    What scotroutes says.
    Although only use if the frame has a raw finish and does not have a painted finish – it will remove the paint/powder coat also!!
    Anodized finish is ok – obviously it won’t be an anodized finish on a Ti frame.
    rocketman
    Hairdryer + WD40 or soap & water
    jonnyrockymountain
    Thanks guys, i’ll be raiding the other half’s cupboard!
The topic ‘removing decals’ is closed to new replies.
