Refurb my DMR
[Closed] Refurb my DMR
[#338370]
Decided it's too much fun to ride, so time for a spruce up.
For the last 5 years it's been covered in camo tape. I stripped it down last night to reveal a couple of small dings in the top tube. Nothing major, but I'm going to get it repainted, so they need smoothing.
Is there any way to pull them out or shrink them?
Painting is going to be diy, nothing too flash, just a bit of colour.
I know it won't look factory, but I like doing these things, used to do a bit of airbrushing.
Any advice on the dents?
Cheers KJ
Posted : 25/02/2009 2:44 am
You're only option is car body filler.
Fill them and sand with a block (flat section of wood with sand paper warapped around it).
as long as the dents are non structural then that should be fine.
Good bikes
Posted : 25/02/2009 10:44 am
No turning back now, just found 2 cracks running around the seat tube from the seat post slot.
No chance of a warranty job on it, so its getting welded.
Now what colour?
Posted : 25/02/2009 11:47 am
which DMR is it? as if its a switchback it might be worth an email, as they were known to crack there and its a manufacturing defect.
Posted : 25/02/2009 11:48 am
what richc said - there was a spate of them a while back.
Posted : 25/02/2009 11:51 am
i had my switchback powdercoated to match my ruller 🙂
cost £20, bargain!
Posted : 25/02/2009 11:52 am
Just emailed them about it, it is a Switchback. Thank for the heads up about that.
Long since lost the receipt for it & the shop has shut, so no hope for a warranty on it.
As for colour, I'm thinking red oxide primer with blue & green grips & brake cables. I'd do a better job if the frame was in better shape.
Posted : 25/02/2009 12:23 pm
once its welded it`ll be fine. its steel after all.
Posted : 25/02/2009 1:03 pm
Well it won't be pretty, but it will be different.
Paint came off easy followed by 3 coats of primer. I'll it again better next time, but for now rat bike/BMX style will do.
Posted : 26/02/2009 9:59 am
have you painted the threads in the BB?
that will be fun for you to clean out!
Posted : 26/02/2009 10:33 am
a LBS will be able to chase the threads out, otherwise it will just take a lot of patience and a stanley knife.
Posted : 26/02/2009 10:36 am
Yes, amateur mistake that. Got a bit keen on getting the spray paint going.
Off to the shop tomorrow to get the headset put back in anyway.
BMX seat may have been a mistake.
Posted : 26/02/2009 10:44 am
So, a year later & another repaint plus a few parts from the Iron Horse.
Posted : 24/02/2011 11:29 am
