I have the 727 frame as a warranty replacement for my 2012 714 and consequently I’m using the RP2 shock from the old frame. For info I am also using x fusion sweep forks at 160mm so the bike is more Spicy than Zesty.
It is ok on my bike with pro pedal on for climbing but I blow through the travel quickly for the correct sag setting, like on my old bike, and the rebound is set low and becomes harsh through rocky sections.
So I am thinking about a shock upgrade although I am slightly sceptical!
I am looking at the rockshox monarch rt3 as this is what comes with the zesty or spicy but not in EI guise. The non EI uses Fox which is also mega bucks! I am looking at the Monarch rt3 debonair which I believe comes with M/M tune only.
Does anyone know what they ‘lapierre specific tune’ is for the 2014 Spicy/Zesty?? Assuming it is not M/M , will I have to factor in a retune from Loco or similar???
