Viewing 14 posts - 1 through 14 (of 14 total)
  • Recommend me a low stack stem
  • fudge9202
    Right , in a pickle with Pikes and steerer tube, pikes are 165mm and headtube is 120mm so allowing for headset I reckon that I would need a stem with 30mm stack height. Any recommendations appreciated
    wiggles
    DMR defy is 31mm.
    cdoc
    One of them? can be run upside down for a bit of rise.
    Or
    Or
    Or the DMR Defy as mentioned above is a good choice.
    Also once had a ragley stubbing which was pretty low
    breninbeener
    Im sure FUNN do a really low stack stem
    ads678
    devash
    FUNN Funduro is 30mm. Decent build quality too.
    fudge9202
    Really like the look of the defy, cheers, any others out there?
    takisawa2
    Crank Brothers, (Iodine ?) was quite low I think.
    core
    Ragley stubbing.
    kayla1
    Funn Enduro stems are 30mm. Incidentally I have a couple of 45mm reach ones with Ti bolts for sale…
    jakd95
    Just got a Ragley Stubbing to solve the same problem. Seems well made and was ~£40.
    scotroutes
    Another vote for a Stubbing
    fudge9202
    Just checked out the stubbing, looks nicely made just a toss between the dmr and it for the job
    submarined
    I’m in the same boat, almost – but even more specific! I need a 35mm clamp one with a bit of rise and light weight!
    Defy seems to be the only one close, but it#s not the lightest 🙁
    Ragley and fun aren’t available in 35mm. What I really need is a low stack Renthal, but I want some stack in reserve in case I want to fit an angleset.
The topic ‘Recommend me a low stack stem’ is closed to new replies.
