I know there's a lot about lights on here at the mo, I have searched and it can all get a bit mind numbing so thought I'd ask instead of trawling through lots of posts
My commute involves a bit of road, mostly cycle path and a bit of off road. The cycle path is only on one side, just away from a major road, and is used for both directions. So, ideally I'd like something that has a low power setting so I'm not blinding drivers but I can be seen, but then when I get to the unlit off road bits I'd like to be able to change it to a bright setting, is there such a thing, something with a remote thumb switch maybe as I don't want to be fumbling around for a small switch. Or would I be better off with 2 lights, one for the road and then switch on another one for the off road bits - again what can I use for the off road bits, any thing with an easy to use remote?
Oh, and cheap and cheerful, of course.
Thanks.
