- This topic has 103 replies, 48 voices, and was last updated 15 years ago by iainc.
Reccomend me a steel hardtail
harryflashmanFree Member
Mboy – I probably should have clarified that in the OP. Almost exclusively XC and singletrack. Not unduly worried about weight, so I’m not discounting the PA just yet.
RudeBoyFree MemberI have a Rock Lobster 853. Lovely little bike. Very light, compared to quite a few other frames. More ‘race’ oriented; 100mm fork is the ideal. I’m running my Rebas at 115mm, so 120mm would need to be run with maybe a little more sag.
Perfect for XC and singletrack. I jump mine off small stuff, couple of foot or so, but I dunno if it’s built ‘tough’ enough to cope with regular 4 foot drops and that. Not what it’s designed for.
There’s a lot of overbuilt stuff, to cope with lardy/rubbish riders. Trouble is, some of the extra idiot-proofing ends up making the frames a bit heavy, if speed is more your thing.
CountZeroFull MemberI’d be the first to admit my 567 isn’t exactly svelt, although swapping the Nixons for the cheap Domains I put on when I had it built up has made a big difference, like around two pounds, but it also has 2.3″ ASX’s on which are not that light, though much lighter than the Big Earls I had for a while, (900gm!). I think it’s now around 30lb-ish, which makes it reasonable for all-day riding, while being up to some hooligan behaviour. Probably a bike that’ll take up to 130-140mm forks, with some reasonable kit and tyres, coming in around 27lb, would fit the bill.
RudeBoyFree MemberPersonally, having ridden them, and inspected them up close, I think the RM Blizzard is one of the most overpriced frames around. Nice paintjob, but nowt fancy at all. I’d say something like a Kona Splosiv or a Voodoo are just as nice, and a whole lot cheaper. Pay a bit more than the Blizzard, and you could have something custom built.
Things like Indy Fab and De Kerf are lovely, but really silly money. Love to have one, though!
MrBlondFree MemberI’ve owned a couple of Inbreds (one rigid, which was lots of fun in an old skool teeth chattering way), a Dialled PA and an Orange P7.
For general riding (with a fitness-related emphasis on going down) P7 or the newer inbred (corrected for 4-5″ forks) – difficult to say which.
For increased foolishness, Dialled PA all the way, very very fast going down
scott_mcavennie2Free MemberI don’t get all this Prince Albert heavy nonsense. Mine’s built for strength rather than lightweight xc spec. I run 721 wheels, SLX cranks, Menja forks (more of a budget choice rather than strength) and no carbon anywhere.
Comes in at 28 lbs which I think is a good weight for an “aggresive” steel hardtail.
awFree MemberI am on the same track as the original OP but I have an old kona cindercone pictured below that I am looking to improve on or upgrade with a modern equivalent. What bike could replace and improve upon (if any) on the cone?
i am still torn between SS and gears and fully rigid and front sus but that is a whole new thread subject I guess!
HTTP404Free Memberyou shouldn’t discount the weight of a frame. a light frame will handle faster and feel more flickable through singletrack. also you should check out the geometries. a slack head tube will be great DH but twisty turny singletrack will feel vague-er. Most the steel frames I’ve seenfall into the 4.5-5lbs. The burlier ones 5.0-6.0lbs. I don’t see much point in carrying around that excess frame weight or fork travel if I don’t need it.
i’ve found the merlins to have quite a compact geometry, the ride position is more upright which is probably down to a shortish top-tube. and remember upping the fork travel on a frame slackens the head angle, heightens the BB, shortens the top-tube and may unduly stress the frame in a way it wasn’t designed to take.
aw – voodoo wanga, orange p7, love/hate (does it have the front derailleur braze-on yet?), gary fisher ferrous are all geared/ss steel frames.
a few more to consider! 🙂
mike-at-dialledbikesFree MemberThank you Scott Mcavennie for writing pretty much what I wrote this morning but the site crashed when I hit send.
The PA frame is a little heavier than the usual comparables, but still easily builds up into a circa 27/28lb complete bike which I think is reasonable for a thrashable trail bike of which only 2 frames have ever broken (1 was broken by Solamanda of this forum and I can’t remember who broke the other 1).
mike-at-dialledbikesFree MemberHTTP404 – Member
“…..I don’t see much point in carrying around that excess frame weight or fork travel if I don’t need it……”
HTTP404, if you can notice it when riding you should turn pro.
si_brodiebikesFree MemberHow about something different? Brodie Catalyst, Tange Prestige double butted frame and a few reasonable bits hanging from it.
RudeBoyFree MemberHTTP404, if you can notice it when riding you should turn pro.
Says the man who sells heavy bike frames… 😉
mboyFree Memberharryflashman – Member
harry, good as the PA is, it’s definitely a bit overkill for just XC and singletrack riding really. OF course it can be built into a 27lb bike, or less, but if you started off with a Cotic Soul, Genesis Altitude, Voodoo Bizango or a Rock Lobster 853, the bike would be over a lb lighter still, and more suitable IMO.
Perhaps a little outrageous a statement Mike. I’m certainly no pro, not even close, but I could tell the difference reasonably easily between 2 frames when riding if one was 20% heavier than the other!
horaFree MemberWe need Lecht Rocks here to enthuse about the nounces of the ride somewhat 🙄
I’ve owned some really lovely hardtails. Really lovely ones but I’d have to say 456. Sorry. Why is it soooo cheap?!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Steel, machined, posted round the world. Duty/tax etc and competitors pricing…yet still cheap. Cheap doesnt equal a cheap ride.
RudeBoyFree Member[/quote]Why is it soooo cheap?
Because it’s mass produced in Taiwan, made of fairly basic cro-mo tubing, and is not quite as well finished as some other models?
And it’s a tad heavy. 51/2 lbs or so?
horaFree MemberIsnt as quite well finished? Mines naked/lacquered. Welds all look spot on to me. Name any other frames on here that arent produced in Taiwan etc? In general steel frames come ‘light’? 🙄
I’m not defending on-one, I didnt like my ti456 although real riders in mags gave it tops marks. I’m just an average rider who doesnt have to care about damaging the frame etc. Its got safe handling, lowish but sadly not gear-queery enough 🙁 but oh well. I didnt like the Cove Handjob either. Its also mass produced but due to the distributor cut etc priced quite highly.groundskeeperwillyFree Membergingerflash-where did you get the chromag? dunno who distributes them in the UK do you?
JamieFree Memberscott_mcavennie2:
Comes in at 28 lbs which I think is a good weight for an “aggressive” steel hardtail.
I agree with you Scott. It is also very subjective, my previous bike to my Alpine (pikes etc) was a RL853 with Reba Races etc, and yet i still do the same distances and the same speeds/averages. At some point the rider has to become an important factor in all this, i.e if you want a fast bike then pedal harder.
davidtaylforthFree MemberPerhaps a little outrageous a statement Mike. I’m certainly no pro, not even close, but I could tell the difference reasonably easily between 2 frames when riding if one was 20% heavier than the other!
Really?
If you built up two bikes with the same geometries and same components, but had one of them have a frame thats 1lb heavier than the other, I bet you couldnt tell the difference. 1lb is **** all when you consider the combined weight of rider and bike.
The way you say 20% makes it sound like alot, but it would be about 0.5% of the combined weight.
RudeBoyFree MemberBut the lighter frame would probbly have lighter, thinner walled tubing, which would have a noticable effect on the ride. I’ve heard people say the 853 Inbred is a nicer ride than the DN6 one, frinstance. Same geometry etc. Maybe only half a pound difference in weight, though. My 853 Lobster definitely feels ‘quicker’ and sproingier (it’s a word) than a DN6 Inbred I tried once. Subtle differences, though.
I’m not a ‘pro rider’, btw…
mike-at-dialledbikesFree Membermboy – Member
Perhaps a little outrageous a statement Mike. I’m certainly no pro, not even close, but I could tell the difference reasonably easily between 2 frames when riding if one was 20% heavier than the other!Not that outrageous, mboy. If I rode a 27lb bike and then a 28lb bike back to back, I probably wouldn’t be able to tell which was lighter/heavier, just which felt better to ride. That might have nothing whatsoever to do with the weight, more about geometry and personal preference.
RudeBoy – Member
It’ll also dent easier.
RudeBoyFree MemberSplitting hairs, now, Mr Heavybikes…
Is the OP going to ride the bike, or fall off it all the time/bash it with a hammer?
I’ve found 853 to be pretty tough. I’d rather ride a lighter bike, than one that ‘does not in any way dent as easily’. I don’t tend to do a lot of crashing anyway. Too busy looking Skil.
mboyFree MemberIn answer to davidtaylforth:
Yes, I would notice it, certainly on a steel hardtail anyway. Primarily for the reasons that RudeBoy outlined in his answer though. A Steel frame weighing under 4.5lb is going to be springier/flexier/more forgiving almost without doubt than a 5.5lb steel frame is. The only criticisms I’ve heard of the Dialled PA for instance (from owners) are that it’s actually probably a bit too beefy for most of their uses, and it’s a little too stiff for a steel frame for XC use, if you compare it to a more “XC oriented” frame such as a Cotic Soul etc. I know my mate likes his lots, but does say it could be slightly more forgiving to ride as it’s as stiff as an ally frame practically.
On the weight front alone though, check your maths before replying to a post eh! A 20% drop in frame weight (let’s say a lb and a bit) is going to be 4% (or therabouts) of the total weight of the bike, not 0.5%. And yes I’d notice it. You’d certainly notice a lighter front end if you replaced your forks for something that weighs a pound less than the ones you are currently running, I’d notice a lb off the weight of the frame as the back end of the bike (by its very nature, a bike frame contributes more weight to the rear wheel of the bike than the front) would feel lighter than it did previously!
mboyFree MemberNot that outrageous, mboy. If I rode a 27lb bike and then a 28lb bike back to back, I probably wouldn’t be able to tell which was lighter/heavier, just which felt better to ride. That might have nothing whatsoever to do with the weight, more about geometry and personal preference.
I’ll agree the difference wouldn’t be night and day, but small subtleties would be present I am sure. Though of course being able to tell these would rely on the 2 bikes being built with the same equipment so as not to add any variables into the mix.
That much I’m not going to disagree with. Lightweight 853 tubed frames can be made plenty strong enough, but with their thin walls they are more susceptible to damage in a crash indeed.
harryflashmanFree MemberGuys, I know you trying to help, but I am neither worried about the odd pound nor am I going to be really punishing the frame to the point of damage. The frame just has to be fun to ride, able to cope with quite an aggressive riding style and be nice and fast going down the hill. I know, I know, not asking for much. For what it’s worth, I have discounted the Cotic becuase of price, and am trying to decide between the On-one inbred, PA and Pipedream Sirius 631.
scott_mcavennie2Free Memberbut does say it could be slightly more forgiving to ride as it’s as stiff as an ally frame practically
No its not.
I’ve moved from a Merlin Malt4 to a PA and the PA is ten times more comfortable than the ally Merlin. I do the same 25 mile loop on either and I’ll be loads more beat up at the end of the journey on the Merlin.
As for it being overkill, it seems perfectly suited to the trails I ride down here in surrey, and I’m comfortable knowing that it has plenty more strength in reserve for trips to the alps for instance. A perfect do-it-all hardtail IMO.
scott_mcavennie2Free MemberThe frame just has to be fun to ride, able to cope with quite an aggressive riding style and be nice and fast going down the hill
Then get a PA.
chakapingFree MemberI’m sure the PA is a great bike, and I really like the look of them – but it’s not what I’d think the OP needs if he’s riding “singletrack and XC”.
He does have lots of choice though, as people have suggested: Soul, Handjob, Altitude, Duster, Pipedream, Sanderson.
I’d also give the P7 and On One a swerve myself for weight reasons, and then look for whichever I could get a good deal on.
Edit: to say Harry made his last post after I’d started this – so I’ll just shut up.
JamieFree MemberCan i just add if the OP does not purchase, build up and post a pic of one of the bikes mentioned in this thread, *cough* PA *cough*, in the next week or so then he should be horse whipped! 😉
chakapingFree MemberCan i just add if the OP does not purchase, build up and post a pic of one of the bikes mentioned in this thread, *cough* PA *cough*, in the next week or so then he should be horse whipped!
And let us all have a go on it!
harryflashmanFree MemberOh lord, thats pressure. What is this monster I have created?
JamieFree Memberharryflashman:
STW Lynchmob baby! Passing judgement since time began
mboyFree MemberWhat is this monster I have created?
LOL
Just remember, whatever you buy, it HAS to be chosen by the masses on this forum, you are not allowed to buy anything remotely different or unique, you will do as you’re told! Ergo you have no choice but to buy a PA by the sounds of things 😉
Nothing wrong with the PA at all, I think they’re great. Just if you don’t need the extra heft/strength in reserve cos you’re never going to jump it or take it to the Alps etc. then why not save a lb in weight? That’s my view on it anyway.
ctkFree MemberSanderson breath/ life: Light, cheap and nicely finished. & Dont see that many about. Go for a size smaller thatn you usually would…
PiefaceFull MemberGo for the On-one. Tough as beans. The 456 will give you more options to run longer forks if you ever go that route in the future. The only reason you may not like it is cos its so cheap, but whats the problem?
IMHO the other options don’t offer much more / look any better / have any more pedigree than the others that you’d pay more for.
ashFull MemberI’m sure the PA is a great bike, and I really like the look of them – but it’s not what I’d think the OP needs if he’s riding “singletrack and XC”.
That’s a load of rubbish IMHO
The dialled PA is one of the best all day singletracky XC bikes I’ve ever had the pleasure to use… it’s geometry is very well thought out such that it climbs as well as bikes a bit lighter, you’d be surprised… and at under 30lb with sensible (not too heavy) bits, it’s not exactly too heavy anyway, unless you’re planning on doing some serious XC racing or something.
chakapingFree MemberAsh – I must admit I haven’t ridden a PA, but when I wanted a mid-travel steel hardtail I ruled it out early on because I felt the weight penalty over many of the alternatives meant it was probably overbuilt for my purposes.
And my purposes sounded very similar to the OP’s in his original statement of his needs.
Of course you can also see in my previous post how I had already qualified my statement in the light of a crossover post from the OP clarifying his requirements.
The topic ‘Reccomend me a steel hardtail’ is closed to new replies.
