rear cassette wobbl...
[Closed] rear cassette wobble-what can it be?
[#1774200]
Just given the bike a good clean and when I've put the back wheel back on, the gears are skipping, so after a quick mess I noticed that the cassette wobbles as though its buckled when I spin the back wheel. Even when the cassette isn't turning and the wheel is, its wobbling around. Any ideas as to what it could be?
Posted : 06/07/2010 2:38 pm
knackered freehub? What's the hub?
Posted : 06/07/2010 2:42 pm
what hub/cassette is it?
 JonR
Either a loose freehub or you missed one of the rings or spacers of your cassette I'd guess.
Posted : 06/07/2010 2:43 pm
The hub is shimano deore and the cassette is shimano, I've had it since new and I'm pretty sure it didn't do that when I got it so doubt its a missed spacer.
Posted : 06/07/2010 2:54 pm
TBH if you read teh threads shim freehub bodys wobble - my mate has an XT hub and wobble quite a bit but does not seem to be causing a problem 🙂
I suspect the axle bends a bit and give rise to freehub body wobble 🙂
Posted : 06/07/2010 2:57 pm
Thanks for the links, just read the posts, I'll just try and sort the gears and leave it alone! If I can't do it then I'll take it to the lbs for them to a a quick look at, see what they think.
Posted : 06/07/2010 3:01 pm
My Deore wheel has this too. Bike hung up, spin the wheel and you can see the rear cassette move about 1mm left to right. Im Guessing there is a slight bend in the axle or the hub flange isn't 100 perperndicular to the axle. Doesnt seem to affect it in use though. I think i've had this with other Shimano wheels in the past, hence why i have hope these days!
Posted : 06/07/2010 3:07 pm
Yeah that's exactly what happens, enough people seem to have had this with no real effect on performance, good enough for me!
Posted : 06/07/2010 3:13 pm
