Here’s one for the “STW hive mind” as I’m a little stumped.
I’m working on a small project and I need some floating motorcycle discs of 280mm diameter – unfortunately discs are sold as fitting a make and model rather than as a size as all the offsets are different depending on fitment.
I’m not bothered about using the carrier as I’ll get a carrier made to suit my hubs, all I want is the disc part and the buttons.
I’d approach some manufacturers but I get the feeling it may be something they’re not keen to do. I just want to just go out and buy some replacement discs for bike that uses this size without getting into long drawn out conversations with a manufacturer where they may decline to sell me some on safety grounds.
The question then is, are there any motorcycles that take a 280mm disc as standard? Floating is an advantage but not compulsory if I can get an aftermarket version that is.
Hope that makes sense.
Gaz
