Charlie, you need to do the cairn/beacon/barrow challenge.
Starting at LH. Wills neck, follow the drove past the gate to triscombe combe and look out for a way into the grassy hill, climb to cairn on the great hill, descend back to the drove and continue to black hill trig(crowcombe) take the gas line to DWD and follow the ST down to sandy corner and go the greatbear, cross road and turn right, climb to the hill fort(danesborough), descend to the next cairn(above knackers hole) then either straight on for bacon butty or come back on yourself and descend to holford combe or carry straight on and go left through gateway(though you’ll miss it and go for a bacon roll)across field and come out at ‘the bumps’if you come out this end go straight over and up towards hare knap (trail to the left of holy bush) if you come out up the combe further, you’ll come out at the ladys combe/devils gallop/frog combe junction, take the next trail left after frog (horizon) and head straight up, left at the top, then right up to hiher hare knap cairn.
*breaths*
Now drop down off the knap heading north and at the bottom of the grassy descent bare left dropping into somerton, right at the bermed corner through water splash and head down the combe, at the ford turn left and go up willoughbys cleavage and up through Holly’s bush (sorry), left at the obvious clearing and up over longstone hill, head over and pootle up to beacon hill and drop to CP, then come back up to Bicknoller post, drop into weacombe and up Bicknoller hill.
*breath*
Left up to thorncombe barrow, dropping off slightly before traversing the contours to thorncombe hill cairn, then it’s a pootle back up past the fire beaters at halsway, at the top, pop over the stile and nip up to Hurley Beacon, back to the stile, back up to the trig, down to crowcombe and back to LH (by way of wills neck if you’ve got the legs)
Sunday downhilling
I did that rote last year but with smiths and not weacombe….take the geared bike..
