Viewing 7 posts - 41 through 47 (of 47 total)
  • PUSH'ed forks
  • trickydisco
    messiah
    Summary – if your not giving your Pike's a beasting and hence haven't noticed that they are a bit rubbish when things get "interesting" I wouldn't bother with PUSH.
    If you have noticed your Pike's are a bit rubbish then consider going for PUSH or upgrading to a better fork… personally I would go for Lyrics if I could afford to change… but I could not so the PUSH upgrade to the Pike's I already had was the best option to improve the performance – especially since I had blown the damper beyond what I could repair and hence needed to get the forks seen to profesionally anyway.
    dasnut
    just received my coil pikes with the new improved PUSH system. I'll report back when I have them fitted to the zesty…..
    Kramer
    Is it worth getting my Fox 32 Talas PUSHed?
    fozzybear
    do you have an issue with the fork?
    Kramer
    I feel that it could be a little plusher.
    fozzybear
    then i would say just service them and fit enduro seals yourself.
The topic ‘PUSH'ed forks’ is closed to new replies.
