Please check my Alf...
[Closed] Please check my Alfine maths
[#2720106]
According to the Shimano web site the Alfine 11 has a ratio range of 0.527 to 2.153 and can take sprockets various sprockets with between 18 and 23 teeth.
So, am I right in thinking that (for example) if an Alfine 11 was set up with a 32t chainring and a 23t sprocket you'd get a ratio range of 0.733 (0.527 * 32 / 23) to 2.995 (2.153 * 32 / 23)?
In comparison a 2x9 gear setup with 22/33 chainrings and a 11-34 cassette would have ratios from 0.688 (22/32) to 2.909 (32/16). So it would have a wider range, but only just.
Have I got my maths the right way round here?
Posted : 05/05/2011 12:53 pm
to speed things up:
http://www.sheldonbrown.com/gears/
has alfine 11 in the drop down
Posted : 05/05/2011 1:01 pm
Sounds right.
Posted : 05/05/2011 1:04 pm
When is the 11 speed Alfine out? Or is it now?
Posted : 05/05/2011 1:06 pm
I thought only 18 and 20t sprockets were actually available though?
Posted : 05/05/2011 1:10 pm
Alfine sprockets are only in 18 and 20T but you can use Nexus ones (no guides on them) which run from 16 to 23T.
Posted : 05/05/2011 1:14 pm
What rootes1 said. ^^
If you want to know anything about gearing, just put the numbers in and see how it compares with what you've already got.
Posted : 05/05/2011 2:38 pm
Thanks for checking my working. 🙂
I only picked the 23t sprocket as it produced numbers that were easily comparable to the 22/32 & 11-32 ratios.
Posted : 05/05/2011 2:48 pm
