Pivot bearings - Ba...
[Closed] Pivot bearings - Ball or roller?
[#533363]
Has anybody every replaced pivot ball bearings with roller bearings?
[img] http://www.signetid.co.uk/gfx/products/bearings/spherical-roller-bearing-2.jp g" target="_blank">http://www.signetid.co.uk/gfx/products/bearings/spherical-roller-bearing-2.jp g"/> [/img]
I'm thinking of trying this as the bearings should transmit the forces a lot less stressfully, however, roller bearings don't like any side load.
So does my Orange 5 pivot take much side load and should I stick with ball bearings?
Posted : 07/05/2009 10:47 am
stick with the manufacturer's recommendations
Posted : 07/05/2009 10:50 am
Of course they take side load.
I doubt you'd find any small enough to fit in any case.
Posted : 07/05/2009 10:52 am
photo is a spherical roller bearing not a roller bearing, smallest size is 20mm id x 52mm od x 15mm wide, its not going to fit!
Posted : 07/05/2009 11:45 am
Looks fairly conclusive then! I'll be sticking with the originals!!
Posted : 07/05/2009 11:47 am
it will if you ever intend to turn corners on it? 😀
Posted : 07/05/2009 11:49 am
Stick with the standard bearings.
Posted : 07/05/2009 12:04 pm
