My current model 29er Pike forks drive side / right side / charger side leg is leaking oil from the bottom after a seal change.
Do i need to use crush washers on both legs, as i’ve not fitted one on this side, on account of not noticing one when took it apart + it has a recessed head to the bolt?
Or am i missing something else, the rockshox manual states:
“Install a new o-ring into the top gland of a new bolt bottom bolt”.
Is that the large o-ring on the outside of the bolt?
“Install a new spring clip in the lower gland of the shat bolt”.
What’s this?
All input appreciated 🙂
