“Not sure on the rebound but you can set it slower than many forks because once you’re deep in the travel the rebound is fast and unaffected by the rebound knob (which only deals with the earlier portion of the travel (“Rabid Rebound”). The rebound setting you need is dominated by the pressure in the fork because that’s what causes the fork to extend, so other people’s rebound settings are rather useless too!”
Thats nice to know cheers 🙂
So set rapid rebound on pretty much how quick you want return for the small bump low travel scenario.
Same with low speed compression I now gather, thats more for brake dive, rolling over small things. Bigger drops are negated by PSI and tokens?
