Panaracer Rampage -...
[Closed] Panaracer Rampage - Will I die?
[#3821967]
2.35", with soft compound on the front and normal compound on the back for my AM full suss.
They do look a lot like a Nevegal, but I figured the softer compound would give me more front end bite. Would I be better served elsewhere?
Posted : 29/03/2012 10:54 pm
Had Rampages for a long time on my Turner. They did the job in the Peak.
I'll be honest the only tyres I've ever hated were conti Vert Pros everything else seems much of a muchness to me.
Using Nobby Nics at the moment because thats what the LBS has!
Posted : 29/03/2012 11:04 pm
I'm running Rampages now after a very brief stint on Nobby Nics (aka the most over rated piles of crap ever). Superb tyres - feel much better than my previous High Roller / Crossmark combo which I thought was pretty much perfect.
Posted : 29/03/2012 11:22 pm
That's the kind of feedback I'm looking for...I didn't get on very well with High Rollers up front, I found them an all or nothing tyre that hated the rutted singletrack round my way. I actually prefer Nevegals, in spite of the toilet paper thin sidewalls.
Posted : 29/03/2012 11:36 pm
I have a Rampage on the back and a Cinder on the front. Works well for me on just about anything.
Posted : 30/03/2012 3:27 am
Rampages were fine for me better than nevegals all day long
Posted : 30/03/2012 6:24 am
OP - I ran the same combo for quite a while...I found that they slice easily on loose rock and the front washes out easily on softer stuff.
High Roller, rear. Minion DHF, front. You could use the Minion F and R too. That's where it's at!
Posted : 30/03/2012 8:27 am
[i]Had Rampages for a long time on my Turner. They did the job in the Peak.
I'll be honest the only tyres I've ever hated were conti Vert Pros everything else seems much of a muchness to me.[/i]
I had Rampages for a long time on my 456. I was never that amazed with them.
I'm now rocking a brand spanking set of Conti Vert Pros. First time out this weekend, we'll see...
Posted : 30/03/2012 8:44 am
Rampages are nice on dry rock, and to an extent, dry dirt.
But rubbish if its wet and sloppy.
Posted : 30/03/2012 9:06 am
Used Rampages front and back in 26 and 29 variants and still got some of them in service. Good all round tyre.
Posted : 30/03/2012 9:10 am
 Del
i ran a rampage on the rear for a while. never really thought much of it, used to spin it on the road climb to the local trails in the damp/cold, and i really wasn't that upset when i put a hole through one of the central knobs of it with only around 25% wear. back to nevegal/blue groove at ~ £5/tyre cheaper...
Posted : 30/03/2012 9:15 am
Used Rampages for a couple of years on my Prophet. Nice tyre. Far better for me than the Nevegals they replaced. I always felt the Nevegals were going to wash out.
Posted : 30/03/2012 9:18 am
Pretty much what ir_bandito said. They got sold on after a particularly unpleasant skate around a wet Whinlatter. 😐
Posted : 30/03/2012 9:21 am
 jwt
Found them to be fairly quick rolling, but quite drifty when pushed hard, nice and progressive though so you can have some control.
Posted : 30/03/2012 9:23 am
Work OK for me. The Panaracer ASB thing is excellent.
Posted : 30/03/2012 9:30 am
They are a good, grippy fast rolling tyre for good conditions. The tread is not very aggressive so get pretty slidy in wet conditions. Their biggest problem, and the reason I only used them once, is that the sidewalls are pretty fragile so were really easy to pinchflat on rocky tracks. Not surprising as they are very light for such a big tyre
Posted : 30/03/2012 9:38 am
As others have said, good in the dry, but they'll have you off in the wet (this is normal compound). I like them for the summer.
Posted : 30/03/2012 9:39 am
