Can someone recommend a headset for a tapered head tube on a 2011 Five? I will be fitting a 1 1/8 straight steerer RS Pike, but will eventually be fitting a tapered Fox Float. Bit confusing with all these Zero stack/integral sets!
Thanks
Thanks
Anyone?
Give hope a buzz - they do a mix and match system and you can get a reducer top cup to reduce 1.5 to 1 1/8 and then a 1.5 bottom cup. They also make a shim that goes on your 1 1/8 steerer to make it fit 1.5 at the bottom cup. This way you could run with the shim with your current steerer then if you later get a tapered steerer you just dont use the shim and it'll fit without needing to change headsets. Hopes website has a PDF under the headset bit which has pics and part numbers. Hope that all makes sense!
Go for the normal Hope Tapered headset, with the step-down adapter race fitted, when you get your new fork it'll just be a case of slipping the crown race from one fork to the other, the adapter can stay on the old forks until you need to remove it.
You must log in to post.
