Options for Shimano...
[Closed] Options for Shimano press-fit BB (BB90)?
[#755712]
The BB on my Zesty has died after about 3 months (it's seen a fair bit of muddy riding but not been jet-washed) so ideally I'd prefer a better sealed option (or something more user serviceable like the Hope BBs). However as it's a Shimano press-fit BB I can't see any choice out there apart from an actual Shimano one (and even then I can't see any different options for models). Any ideas?
Posted : 03/08/2009 10:45 am
It's just a pair of bearings, any bearing supplier should be able to come up with something. You could try some full compliment ones, or ceramic ones.
Posted : 03/08/2009 10:48 am
I'm looking to replace the entire thing though not just find new bearings as once I've taken it apart it's going to be even more poorly sealed than when it was new...
Posted : 03/08/2009 12:10 pm
But if it's BB90 there is no sealing, it's just 2 bearings pressed into the frame, surely there is nothing else. That was the point of BB90, which Trek designed originally for the Madone, it does away with cups and everything. This sounds like a different system again!
Posted : 03/08/2009 1:19 pm
check whatever bearing you get for grease, plenty start off dry and soon corrode.
Posted : 03/08/2009 1:23 pm
@njee20 - piccie of BB below, I wouldn't fancy my chances of finding something non-cycling specific that would fit and be properly sealed...
@cycnic-al - sound advice but the tricky part is not damaging the seals when taking them apart
I'm just surprised no one else has had a similar issue given how popular the Zesty & Spicy seems to be.
Posted : 03/08/2009 2:11 pm
Oo, me neither, that's nothing at all like all the BB90 systems, which are simply a pair of bearings, that's a 3rd standard altogether!
I imagine that's Shimano or Shimano, and you may even struggle to get one of them!
Posted : 03/08/2009 2:23 pm
total myth IMO. It's not a part made with microscopic precision!
Posted : 03/08/2009 2:25 pm
Its not BB90 its just XTR bearings.
As far as we have found we cannot just place bearings in the shell as mentioned above and it seems that this is the only BB we can get.
In the shop we sell a lot of zestys and spicys and we have only really had a couple in for BB replacement. Mine got super stiff the other week so i just GT85'd it cause it had been wet and it works perfectly again.
the bearings inside are tiny, in a retainer race as well so there isn't actually that many bearings.
The removal from the bike process is pretty destructive too - you need to belt them out!
Mark
thebikechain
Posted : 03/08/2009 3:05 pm
Mine has just gone in my zesty. As far as i could work out there was no choice but replacing like for like at £50 for the shimano one.
The bearing cover came off pretty easily when i was having a play so might pay it a bit more attention than the last one in terms of cleaning and regreasing the bearings with the cups in situ to see if i can make this one last any longer.
Posted : 03/08/2009 3:10 pm
markd - Member
the bearings inside are tiny, in a retainer race as well so there isn't actually that many bearings...
I thought the point of bb30/90/whatever is that the bearings are bigger?!?
Posted : 03/08/2009 3:16 pm
Bummer, was hoping for better news on options but at least I know I'm not the only one getting shafted for £50 crappily sealed Shimano bearings 😉
@markd - out of interest have you had anyone fit a bash guard or chain device that uses the ISCG tabs? As near as I can tell most devices rely on them being flush with the BB face but on the Zesty they're set way back (where a normal shell would stop not the 90mm on the Zesty).
Posted : 03/08/2009 3:22 pm
hey
bash guard.... not yet although James in the shop has just got the metal bit for a DRS. Using it on a spicy, not fitted yet though.
Its meant to be ISCG05 though... just that it might involve some tools...
pjt201 - the bearings are v small. it allows a larger shell for stiffness sure but the actual physical ball bearings are pretty wee.
Posted : 03/08/2009 3:45 pm
I have a e13 DRS (ISCG05) mounted on my zesty
fits a treat with no special tools. The hole in the middle of the backing plate that carries the jockey wheel is much bigger than the BB housing and sits outside it.
My BB has started creaking like mad, hence stumbling on this thread.....
Posted : 17/08/2009 7:56 am
It is, but that's neither BB30 or BB90, that's different for the sake of being different!
Posted : 17/08/2009 9:14 am
Yeah some article I read referenced it as BB90 but it's not. Still actually waiting on getting mine replaced as the LBS forgot to order it (been injured so not in any hurry).
The proper removal and installation tools look very basic but stupidly expensive, will probably hold off buying them for now and see how long the second BB lasts to see if they're a worthwhile investment.
The bashguard I have (MRP triple ring one) doesn't quite fit over the BB shell so I'm just going to widen the hole until it does and then see if the bits are in the right place.
Still not sure why they use this type of BB on the Zesty - I guess to allow a wider BB shell, still seems a lot of faff though.
Posted : 17/08/2009 10:15 am
BB on my Spicy has just died too - any idea where I can get spare bearings from? Can't see anything on Chain Reaction or the usual suspects.. Ta
Posted : 14/09/2009 5:03 pm
One side of mine died after 4 months on my Zesty and had a little trouble finding out initially, how to remove the bearings on their own. Bearings can be gently tapped out of the plastic housing from the other end of the bb, using a sharp chisel and pressed in as normal. Just remember to use a little grease in the plastic housing, or It'll creak like mad!
Posted : 15/09/2009 8:47 pm
Acros as far as i know are the only people who are producing BB30 & BB90 bottom brackets other than Shimano.
Prices are the same as the regular HT2 BB's & come in Stainless or Ceramic options.
J
Posted : 15/09/2009 9:09 pm
 ojom
*coughs*
http://www.thebikechain.co.uk/acatalog/Zesty_Spicy_Bottom_Bracket.html
*coughs*
Posted : 15/09/2009 10:32 pm
BB9141A is the Shimano part number for it, my replacement's still going strong after 2 rides :p I'm hoping someone that knows how to do decent seals makes an alternative soon.
Posted : 16/09/2009 8:23 am
So, many people have spicys/zestys so BBs must have been renewed by now...so is there anything else on the market at a decent price, or any way of removing the push fit cups without destroying them?
Posted : 26/12/2009 8:54 pm
I recently fitted one of theses
http://www.chainreactioncycles.com/Models.aspx?ModelID=44225
Posted : 26/12/2009 9:07 pm
 ojom
Rockdodger - that is the standard one.
You can't really get em out without damaging them.
The situation is the same as it was 4months ago, just the Shimano ones as i mentioned before (markd). If i am wrong then someone please let me know.
http://www.thebikechain.co.uk/store/product/18633/Lapierre-Shimano-BB-for--Zesty-Spicy/
Posted : 26/12/2009 9:14 pm
Urgh, cheap gits. I cant see any advantage of a press fit BB over a threaded HT2 jobbie? why on earth have they turned to these at manufacture? theyve got to be cheaper. I quite fancied a zesty, but not bloody likely now.
That said, ive been jet washing my bike for the last year or more, no probs with any of my bearings. but then again, I know how to service them once in a while.
Posted : 26/12/2009 9:18 pm
 ojom
Don't let a wee BB put you off a bike... they last ok. On my second (in 12 months) after a ton of use and never cleaning them, ever.
Been through other BB's quicker. Just don't over tighten the preload as most people are want to do.
Posted : 26/12/2009 9:25 pm
Hey Grimy, having read up on the lapierres BB90 it sounds pretty cool actually - some definite advantages over the standard BB, however, like all new things there are limited choices for bearings right now.
Shimano or Enduro are the only options Ive found so far.
I think my bearings are now toast too hence why Im looking for a replacement set - giving the crank arms a push it only spins half a turn with no chain attached! <groan>
Posted : 28/12/2009 3:18 am
As it looks like Ill be attempting this in the next few days - any advice as to how to remove the existing bearings and press in new ones safely without spending mega-££££ on the proper tools?
Posted : 28/12/2009 3:33 am
Stop talking about BB90, that is a Trek system, this is not BB90
Thjis is sometimes referred to as BB86, or himano standard press fit.
FSA currently make a stainless bearing and a ceramic bearing kit for BB86 and also another type, can't remember the name at the moment, got it written down at work.
Ask your Lapierre dealer to look in the FSA 2009/2010 brochure, there is a whole page on BB's that are of a quwirky nature. Or call Windwave, they had them in stock last time i called. Go Ceramic, smooooooth.
FSA cranks will not fit through a shimano, or Hope BB
But all shimano cranks will fit through an FSA BB fine.
Posted : 28/12/2009 8:57 am
Looks like the bearings themselves will be standard ht2, you can pull out the outer seals and then the bearing race seals and pump more grease in, the bearings themselves can also be replaced in ht2 (even though it says do not disassemble on them)so can't see why you shouldn't be able to do this, you could most likely fit some enduro or phil woods bearings back in to replace the shimano ones.
Posted : 28/12/2009 10:10 am
The bearing are the same size as HT2 'S and can be drifted out with care.
Posted : 28/12/2009 10:50 am
just found this: [url= http://blog.superflycycles.com/?tag=bb86-bb92-bottom-brackets ]click[/url]
I shall be investigating further.....
Posted : 29/12/2009 12:56 pm
[url= http://www.enduroforkseals.com/id256.html ]HAVE IT[/url]
I'll be ordering one today...
Posted : 29/12/2009 12:58 pm
dasnut - Did you get one?
My Zesty's BB is on it's way out and was thinking of giving the Enduro ones a go.
Posted : 26/01/2010 6:42 pm
Just ordered one myself, had a right proper job getting the old one out though (hammer and screwdriver), £50 for the shimano removal tool is starting to look OK. Anyone having problems with thier headset?, another bit of cheap kit in my opinion, nice bikes let down with cheap kit.
Posted : 29/01/2010 5:53 pm
Took mine out with a screwdriver...new ones are £50 so put the old one back in. It was abit mangled, but bodge job works...
Left out the sleeve and packed the new bearings with grease...been going since end of december just fine!
My headet bearings have been fine. Stripped and re-greased every now and again. They are just normal integrated bearings so dont know if noticably higher quality can be found...
Posted : 07/02/2010 7:00 pm
Did any of you guys that have replaced the Zesty BB notice water in there? I get an eggcup full in my seat tube every wet ride, which I'm assuming will destroy the BB fairly soon. Does the water get in through the BB?
Posted : 25/02/2010 6:44 pm
If anyone is interested....
The water was getting into the frame down the seat tube/clamp area. I've fixed it by stretching a piece of innertube over the clamp and seattube and holding with zip ties.
No more water in my frame anyway.
Posted : 01/03/2010 6:04 pm
I've been getting loads out of the frame after a wet ride and it must go somewhere other than just down the seat tube as you need to hold the frame at various to get all the water out. I tried using a strip of electrical tape and a neoprene headset guard to stop the water running down the tube but it's still getting in a little.
I've also now jammed a bike tag 'bung' down the seat tube which I'm not sure is a good idea as if any water does get passed it it can't escape 😐
Posted : 01/03/2010 6:35 pm
Yes - tried all the tape/neoprene things without any luck myself.
The inner tube thing does work though, just a bit of a faff getting it stretched over the clamp. If you have a QR, you'll need holes, which I made by putting puncture repair patches on the relevant areas first - that way the rubber doesn't split. One ziptie above the clamp and one below and job done. I also put a square of innertube in the thomson clamp, to cover the top of the seat tube, which is open and only covered by that U shaped piece of alloy.
Posted : 01/03/2010 7:00 pm
Any idea if this is the same one for 2010/11 Fuel EX Alu frames. Looks like mine, and struggling to get it appartt, looks like you replace cups and bearings
http://www.thebikechain.co.uk/Lapierre-Shimano-BB-for-Zesty-Spicy-8888888013730/
looks like its this part SM-BB91-41A from here, fitting instuctaions too
http://techdocs.shimano.com/techdocs/blevel.jsp?FOLDER%3C%3Efolder_id=2534374302051856&ASSORTMENT%3C%3East_id=1408474395181679&bmUID=i.Sdrrd
Posted : 18/06/2011 11:44 pm
