One hardtail to rul...
[Closed] One hardtail to rule them all... what frame?
[#567344]
Bit of a slow work day today. So...
I have upgraded my cheap alu hardtail to the point where the only original items are the frame and the headset. Obvious next step: new frame.
Requirements:
-Light enough to blast 30 mile XC routes as fast as my fitness will allow
-Strong enough to handle rough terrain, e.g. fast rooty downhill with repeated 1ft steps
-Maybe even strong enough to handle small jumps - would like to learn to be more comfortable with a little time in the air, but not full on DJ or anything
-Cheap
-Sexy
To give an idea, bike spec that will be fitted is:
685mm wide bars
SLX brakes 180/160
Mavic XM719 Rims / Kenda 2.1" Tyres
RS Tora Coil U-Turn 85-130mm
I know it's probably asking a bit much, but it's good to get an idea of whats possible. The only thing that immediately leapt to mind was a Stiffee - light and bombproof. Only problem is that they're quite pricey. Advice/Abuse welcome. Do I even need a stronger than average frame?
Posted : 20/05/2009 1:25 pm
Have a look at a Marin Rocky Ridge, sounds spot on for what you're doing and you should be able to pick up a cheap frame second hand.
Posted : 20/05/2009 1:31 pm
Dialled Prince Albert?
Posted : 20/05/2009 1:35 pm
Santa Cruz Chameleon my do it all bike, tis perfect for everything. My bike build theosophy is:
Be as light as possible, be able to survive a uplift day, and be comfortable enough to ride a marathon on.
Build: Chameleon, Pikes, 819, Hope, XTR, XT, Thompson
Pic (ignore mud guards they were needed under the circumstances):
Light AND Strong ?
I'm not superfit but I can still easily do 30 miles of hilly terrain on my steel frame so I'd say go for steel over ally
I suspect a Stiffee would be overkill, I know it is for me - but then again, I love it anyway. Don't think I'd have bought one full price though. Does it have to be Alu? What about an Inbred / 456? I think that's what I'd be looking at if I had to buy a new hardtail with a sensible budget.
Posted : 20/05/2009 1:38 pm
Orange P7
Posted : 20/05/2009 1:40 pm
PA,Soul,456.
Posted : 20/05/2009 1:41 pm
2nd Chameleon, that's what I'd get in your instance.
Posted : 20/05/2009 1:42 pm
steel framed, 100-140mm travel.
most bike should be able to deal with 1ft drops. if not, the problem lies with the rider/riding style.
Posted : 20/05/2009 1:45 pm
Sounds like pretty much any frame that will take a 130mm fork, but still will ride all day
On-one inbred
(On-one 456) - on the heavy side
Pipedream Sirrus
Ragley mmmbop/blue pig - not out until late june
Kinesis Maxlight XC<120
Dialled Bikes Prince Albert
Orange P7
Cove Handjob
Cotic Soul
(Cove Stiffee) - quite stiff?
(Santa Cruz Chameleon) - quite stiff?
Must be loads more
Posted : 20/05/2009 1:47 pm
 pjd
P7 - I built up a cheap 2nd hand 05 (i think) frame with some not so cheap bits and it is awesome.
Perfect fit for your forks
Posted : 20/05/2009 1:48 pm
Commencal combi?
Posted : 20/05/2009 1:51 pm
on-one Scandal with 120/130mm fork
Posted : 20/05/2009 1:52 pm
 wors
I have the same dilemma, i'm hoping one of the ragleys will be the answer.
Posted : 20/05/2009 1:53 pm
Lots of food for thought there. I'm in no rush, so I am prepared to go second hand. Does anyone here get 'airtime' on their hardtails - is it safe to do so or just asking for trouble? Couple of Chameleon reccommendations there - they look nice but I had heard they are incredibly stiff, is that true?
Posted : 20/05/2009 1:59 pm
Orange P7 all the way.
Posted : 20/05/2009 2:03 pm
Having read the May issue of Singletrack's and the Budget Makeover article I’m now considering the Santa Cruz Chameleon. But I do have a test ride on a Ragley coming up soon so think I’ll try get a ride on a Chameleon as well.
Have a go on one and see for your self its the best way.
Posted : 20/05/2009 2:05 pm
The Stiffee is extremely stiff too. There's a clue in the name 🙂
Posted : 20/05/2009 2:06 pm
Does the Chameleon change colour then too? 😆
Posted : 20/05/2009 2:07 pm
I love my On-One. You could buy a new one and get it sprayed whatever way you like and still have change from £250
Posted : 20/05/2009 2:09 pm
That's a pont - why don't they paint it with ink that changes with the temperature like those Global Hypercolour t-shirts back in the early 90s?
Global HyperCruz!
Posted : 20/05/2009 2:13 pm
Go for one of these and then you can SS it when you get bored.
Posted : 20/05/2009 2:14 pm
 hora
Posted : 20/05/2009 2:16 pm
I'd say a chameleon myself but it is a very stiff bike and will screw your back over long rides. Not hugely light neither. You'll never snap it though and it is a hugely fun thing to rag about the place.
I've got an expensive handjob and a chameleon and the chameleon gets way more riding done on it.
Posted : 20/05/2009 2:27 pm
Ha!
As someone says above, it does depend very much how smooth a rider you are. I've broken spokes and even smashed the bearings in my rear hub doing fairly little drops like the one above, so I'd go with strong.
Posted : 20/05/2009 2:30 pm
One other thing about alu frames is that the walls of the tubing are generally thicker than steel ones. So they are (generalising wildly here) more resistant to dents, and a steel frame that's designed to survive the sort of front-on impacts you get in dirt jumping or DH will be very overbuilt and probably heavier than an alu equivalent - although it varies and there are some waaay overbuilt alu frames out there too.
The angles and lengths are really important in a frame as well as the contruction, you may want something fairly short so it's easier to pick the front up for drop-offs.
Posted : 20/05/2009 2:34 pm
I think I have some work to do on smoothness. Currently learning to bunnyhop consistently enough to clear obstacles safely. Trouble is, when I do it, it looks like someone superglued a guy to a bike then tazered him.
Posted : 20/05/2009 2:42 pm
A PA is definately worth a look.
Posted : 20/05/2009 2:45 pm
Yeah, I have heard horror stories of people dirt jumping XC frames and ripping the head tube off!
Anyone know what sort of weight difference there *typically* might be between a robust steel frame and a robust aluminium frame? I was assuming it would be of the order of 1 lb or so.
Posted : 20/05/2009 2:49 pm
Don't think it's that much. More like 1/2 lb?
Posted : 20/05/2009 2:52 pm
Well a PA is 5.5lb (and its a strong steel frame) and the Cove is 4.5lb's so a lb doesn't seem a million miles off. Bfe's are a bit lighter but much more expensive (but still cheaper than a new Cove)
The Ragley Ummbop is only 3.7lbs so its much lighter than a steel frame, but its a bit of a unknown considering you can't even buy them yet. If they do turn out to be any good I should imagine they will be very popular, as they will be strong, cheap and light.
Posted : 20/05/2009 2:57 pm
P7
Posted : 20/05/2009 2:58 pm
one important thing IMHO is the ability to run an adjustable seatpost, so ideally you want a 30.9 or 31.6 seatpost.
Posted : 20/05/2009 3:01 pm
Oh no they won't! Pick any two.
Whyte 19 would get my vote. It did in fact, and it's awesome
Posted : 20/05/2009 3:40 pm
Chameleon's not that bad in terms of stiffness, certainly no worse than any other ally hardtail (with massive fat chain and seat stays...), plus you can mitigate it a bit with a carbon post, and a squidgy saddle. I can ride all day on mine, no worries, did a 55 mile loop the other day on it, and I wasn't crippled by it.
Posted : 20/05/2009 3:41 pm
The thing I like about the Budget Makeover article is the bit where it says (the oft-neglected mountain bike genre of “just riding along”) that’s what I do just ride along. Sometimes XC ricer sometimes Play Bike and sometimes Filth Riding but never enough of one or the other to get a specific bike for the job.
Posted : 20/05/2009 3:45 pm
[url=
]'airtime' on a hardtail[/url]
it is more about the rider than the frame when it comes to jumping. a full-suss will let you get away with things if you cock up and are not smooth.
Posted : 20/05/2009 3:47 pm
They don't get any love on here so I'm going to say a DMR Trailstar is a great bike for not much money £299.99.
Posted : 20/05/2009 3:55 pm
How good of an 'all-day' bike is a trailstar though? Aren't they more of cross between a normal do-it-all hardtail and a dirt jump bike or more like a 4X frame?
Posted : 20/05/2009 3:59 pm
mike_p - Member
Well at £275, 3.7lb and they exceed the new CEN testing (which a lot of steel frame's don't), it appears that they are
Time will tell though
Posted : 20/05/2009 4:05 pm
PAs were raced at national level 4X, they can take jumps!
Posted : 20/05/2009 4:08 pm
That'll be a P7 then . . . .
Posted : 20/05/2009 4:18 pm
 hora
must admit that carbon Whyte is mightly tempting! Not for me but for people who earn good money!
Posted : 20/05/2009 4:20 pm
For the price of the Whyte Carbon frame, you could get an Ibis Tranny, and I know which one I would prefer.
Should be OK to jump, if Lopes is racing 4X on it
Posted : 20/05/2009 4:23 pm
