On-One wheels - any...
[Closed] On-One wheels - any good?
[#969422]
Reetard rims plus cartridge bearing centrelock hubs etc.
Posted : 20/10/2009 7:05 pm
i've got no complaints for the ones on the singlespeed
Posted : 20/10/2009 7:22 pm
Same here on my SS, I have changed one set of bearings in one, they are 3-4 years old!, strong rims and i run down the DH tracks (slowish to middleish) but they are prob, heaviest wheels in the house
Posted : 20/10/2009 7:26 pm
Anyone got the link that shows how to replace the bearings in a planet X rear hub ?
STS
Posted : 16/11/2009 5:54 pm
 Bazz
STS, don't know of any links but if you use a cone spanner to remove the cover on the non drive side then use a cone spanner to grip the drive side cover and insert a 5mm allen key into the non drive side you can undo the free hub and then knock out the axle and non drive side bearings and then knock out the drive side bearings, hope this helps a little, it is pretty easy.
Posted : 16/11/2009 6:26 pm
