Odd because I’ve not had this before and google is letting me down on this, so I’m turning to the collective singletrack wisdom….
Went to do a bleed on a 1st gen reverb stealth, did the usual process of: raise front end of bike; raise seatpost to full extension; rotate mount round so screw was at the high point; wind the speed out to slow; bleed screw out of remote and pop a 1/3rd filled syringe in there; same at the post end with 2/3rds full then the in-out/push-pull of bleeding the system and took everything back out. Nothing unusual so far, but when I go to press the remote it is absolutely solid now. Maybe 1mm of movement.
I’ve retried the process a couple of times now and done the remote bleed too, but nothings made a difference and it’s fairly rapidly making me want to throw the damn thing out the window – so has anybody hit this before? How am I screwing this up ?
