My new Bizango is settling down nicely, the forks are even starting to feel like they work (a bit) but the noise from the chain is driving me mad!!!!
It’s only in the two largest sprockets, in the middle ring. Chain isn’t rubbing on the front mech. Its much worse under load, but when pedaling very slowly, it feels like the pedal bearings are knackered, but in the granny ring or further down the cassette the feeling/noise goes away.
Any ideas? Something is obviously not right, it didn’t make this noise when it was new, but I don’t think it’s chain stretch as the indexing is fine and shifting smoothly.
The bike has sliding dropouts, I’ve checked these are straight and tight, and I’ve even tried sliding the whole lot forward, which has helped but not cure the problem (backwards was worse).
Cheers in advance
