I have Orange Strange grips on 2 bikes and they are getting pretty worn - I get on well with them, and like the size and feel. Do I just order 2 more pairs or is there something similar, better, cheaper, longer lasting out there ?
Thanks
Thanks
superstar, cheap and grippy
bluebell II by rOcKeTdOgUk, on Flickr
I use ODI X-Treme and ODI Cross Trainer on my bikes and they've both been good. I like the mushroomy 80's texture of the Cross Trainers, but they do get lots of crap embedded inside the filaments.
those Superstar ones look very similar to the Orange ones - will have a wee look, cheers
+1 superstar or odious ruffian.
Troy lee ODI ones, they're brilliant! (touch pricey though)
Oury lock-ons on all my bikes...great grips: big and squidgy (but not too squidgy)
If you go for the Superstar ones, I'd go for the Excel ones if you like thick grips, they are a bit bigger than the ones in Rocketdog's picture:
http://superstar.tibolts.co.uk/product_info.php?cPath=60&products_id=437
They aren't as grippy as some of the more expensive ones in the wet, but when the grips wear out you can get replacement cartridges for £6 quid, in loads of colours too. Bargain.
Lizard Skins North Shore: I've just got them for my SX Trail and they feel amazing, easily as good as the ODI Rogues I was using previously. However, I do prefer larger diameter grips, so they may not suit if you prefer them on the small side.
The ODI Troy Lees are the best grips I've ever used. Have them onb two bikes, love them.
I recently got some on-one bobons. Previously have used oury, big earl and cane creek.
The ODI based ones have two allen bolts aligned sort of tangentially with the collar, so even when screwed tight, the head is proud a little and can be a bit uncomfortable.
The On-Ones have small allen grubs that are perpendicular to the collar and screw in countersunk so they do not stay proud. Much better IMO. However, since they are new on I dont know whether the design difference has any other performance implications.
thanks all, Superstar regular ones ordered - they look very similar diameter to the Orange ones and seem like a good deal !
i've used these for about 100 years.
ODI Troy Lees here too. They're not super-thin though (which I know a lot of people like).
Neither are they particularly long, so there's only really one hand position.
But I like them a lot and I quite like a thickish grip (got ODI Mushrooms on my hardtail).
Yeti for ever
ODI Rogues for me.
Stoner - MemberThe ODI based ones have two allen bolts aligned sort of tangentially with the collar, so even when screwed tight, the head is proud a little and can be a bit uncomfortable.
Have never noticed that, and I've used ODI for years
ODI ruffians for me, but only because I needed them and the shop didn't have the Orange Strange ones is stock.
ODI Ruffians here. Worth the extra cost over the cheaper copies imo.
I should mention Nuke Proof grips here - mate had a set of them. They needed two different sized allen keys, for some reason - the inner bolt was larger than the outer. Man, that bugged me.
Lizard Skins Charger grips here. I find them excellent.
Lizard kin Peatys are the best I've used but are always close to £20 , superstars are fine as are Outland Enduro which are only £9.99 from JJB.
Hahaha this great, the OP has already said that he's ordered some, and yet suggestions continue to pour in.
You must log in to post.
