no high speed compression
– no need to adjust that, then
the rebound is only the beginning stroke rebound
so set it so it feels right at the beginning of the stroke
Seriously though, Rev’s aren’t difficult to set up. No point worrying about what adjustments you don’t have. Set your air pressure to give you correct sag and/or minimum bottoming out. Equalise positive and negative pressures unless you want a really progressive feel. 3 or 4 turns of rebound to stop it coming back at you too hard. Don’t overdo it – if it squelches like a Fox or Marzocchi, you’re running too much rebound.
Then go and ride.
