Need help identifyi...
[Closed] Need help identifying a bike part !!
[#2663165]
Now I truly thought I knew the name of every darn thing on a bicycle - but alas, I cannot put a name to the these little buggers - that I now need!
Can you lot help?
The circular things ... they are the little bits that go with down-tube shifters ... And I have lost mine !
Any clue what they're called ?? Or where to purchase??
Cheers very much
Posted : 14/04/2011 11:20 pm
I only need 1 - for a dingle-speed experiment ... will gladly buy off someone here if they have a spare
Posted : 14/04/2011 11:22 pm
Probably referred to as spacers in some way. None at SJS then?
how did you google for the image?
ebay buy some shifters?
you can use a washer instead on the inside as it catches the square post bit not as pretty but a reasonable fix
Posted : 14/04/2011 11:28 pm
they appear to be called 2
Posted : 14/04/2011 11:30 pm
Ooh Clubber, your 'spacer' comment led to a interesting google search ...
I think I'm looking for a sl-7900 friction cap ! ... maybe 😕
Posted : 14/04/2011 11:31 pm
Another way would be to buy a road gear stop (that fits on the same part of the frame) and then just use a hacksaw to cut it down to the bit you want.
Posted : 14/04/2011 11:32 pm
Pretty sure I've got some spare, I'll have dig around.
Mail me ur address and I'll stick um in the post!
TVM
Posted : 14/04/2011 11:34 pm
Success !!
Cheers for the help guys .. steered me right on the path!
It seems I need a 'Lever boss cover - for light alloy frames' Hurrah.
I'm sure madison will be able to get me one in .. oooh 6-8 weeks.
*EDIT - The van man .. that would be much appreciated !! - I need the 'flat' kind it seems
Posted : 14/04/2011 11:40 pm
