MOT experts - CV jo...
[Closed] MOT experts - CV joint gaiters?
[#458555]
MOT is coming up in a week or 2.
I have one CV joint gaiter that is beginning to crack/split. It hasn't actually gone through yet - no grease leaking out.
Will it be OK like this or is any damage to the gaiter a straight fail?
It'll get done eventually, but if I can put off the cost a bit longer then that's good.
Posted : 08/04/2009 7:19 pm
Put scruffs on, buy a kit for £12 and 30 mins job done.
Posted : 08/04/2009 7:31 pm
You'll prolly get an advisory note about it, if the grease can't get out then it's not a fail.
I think!
Posted : 08/04/2009 7:32 pm
I'm pretty sure that 'perished' ia a fail, not dead cert though. It's gonna need doing anyway & once it's split & all yer grease flies out it's not long before the joint goes west as well, more expense! What car is it?
Posted : 08/04/2009 7:56 pm
its easy enough to do, get some spring retainers and be very careful and you'll be fine.
Posted : 08/04/2009 8:01 pm
If its secure at each end and not leaking any grease out, then its a pass.
But don't take it to Quick fit outfits. Best place is local council garage as they are not looking for work on Jo public's cars.
Posted : 08/04/2009 8:12 pm
I have "stitched" the hole up with a few cable ties in the past,you have to be carefull as the gaiter needs to move a lot on the outer cv joint,it has got me through mots in the past, but it is really a temporary bodge if your keeping the car long term.
get it fixed asap if you can,any major water/dirt ingress will accellerate wear in the joint eventually. 😥
Posted : 08/04/2009 8:45 pm
if its only cracked and not split it should pass with an advisory no problem 😀
Posted : 08/04/2009 8:47 pm
You can buy a split gaiter kit - you get a split gaiter and a tube of glue. Saves a lot of expensive dismantling. My old 305 got by on one every other mot for a few years before the end. I miss my 305 though!
Posted : 08/04/2009 11:09 pm
I think you'll get through, but you get 2 weeks anyway if it fails iirc
split gaiters are REALLY fiddly, but it's so much hassle to put anew one on otherwise.
Posted : 08/04/2009 11:24 pm
