cubemeup – Member
my brother has the 2010 enduro comp stunning bike but your knackered if you want to upgrade the shock!!
I’m in the slightly better situation as I have the Evo. I think I can change for most if not all coil shocks. Until recently I wanted to put an air shock on it, now I have sorted out the spring rate and it is amazing.
I’m sure Mojo will carry the stanchions with the silly eyelets for the normal frame, if this is the case you could probably swap to just about any Fox air shock.
