OK so I've just topped them up to 190 as advised on the Marz site but now can only get about 6-8cm travel before they stop dead. I'm guessing the oil levels are too high despite what the online manual says. Any ideas?
According to this info over on ridemonkey.com which I've just found, the rebound cartridge leg should only have 33cc and an oil height of 55mm with the forks compressed (I'm guessing measured from the top).
Forks are pretty simple internally – sealed rebound damper cartridge in the left leg and coil spring (with air preload) on the right side.
