M785 Pad Axle
[Closed] M785 Pad Axle
[#3274908]
As I'm a complete numpty I've managed to lose the pad axle from the rear break. The part code according to the tech docs is Y8JZ98010 but I can't find one on the net. I've mailed Madison but no reply as yet and it means I'm bikeless till I get one sorted!
Any ideas?
Posted : 24/10/2011 1:21 pm
A big split pin is about your only option if you can't find a replacement (that's what they supply for Deore brakes anyway, so it does work quite well).
Posted : 24/10/2011 1:40 pm
Can anyone point me in the right direction, not sure what I need?
Cheers.
Posted : 24/10/2011 8:30 pm
[img] http://cdn.priceprobe.net/i/7194335.24744df9aa87485a77.06074638 [/img]
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_206737_langId_-1_categoryId_255228
Something like that. Not quite sure on the size.
Your LBS might have something lying about...
Posted : 24/10/2011 8:43 pm
You could go to your LBS and ask them to order part # 8JZ 9801 from Madison. It's a carriage free item so the shop won't need to wait until they have a minimum order before placing then order. However, the part is currently out of stock and there is no due date.
Don't you get a new one if you buy a set of pads?
Posted : 24/10/2011 8:45 pm
LBS, if only there was one of those round here that I had any faith in. Out of curiosity, how do you know they are out of stock?
Posted : 24/10/2011 9:07 pm
I logged into Madison's B2B site and checked.
Posted : 24/10/2011 9:13 pm
Fair do's, I have managed to find one on a German site (bicikli.de), if Madison don't come back with anything tomorrow I might have to order through them, not keen on bodging it.
Thanks again.
Posted : 24/10/2011 9:26 pm
