Have some Feb 2013 Air MiCo 160 lyriks and I’ve put in a new DH MiCo compression Damper.
Firstly can I just confirm the damper volume is 184ml for this model year? I drained 201ml out of it which seems way to much, although earlier ones were 193ml.
Secondly I know it is designed to work out on the trails, but messing around up and down curbs and braking seem to have no difference with the LSC fully on or off – pretty sure originally I could tell some difference even with just a few clicks. Sag is 25% and rebound adjustment is working as it should and forks feel a lot better after a lube change too.
