Anyone got any suggestions ?
I've got one of those little clamp on cable oilers, but whgen I put it on the end of the cable the GT85 escapes between the cable liner and the aluminium segments rather than going up between the liner and the inner cable. Middleburn oilers would almost certainly do the same if I fitted them.
There's an old motorbike trick of making a plasticine funnel moulded round the outer cable or a plastic bag funnel taped tightly to the outer.
I've had the inner wire wear right through the liner and a couple of the segments in the past, so I could do with some quick and easy way of lubricating the cables.
It's a Rohloff with two full length cables and a twist grip so it doesn't take much resistance to make it almost impossible to change gear.
