- This topic has 76 replies, 35 voices, and was last updated 9 years ago by RamseyNeil.
LBS issues…. Grrrr….
PeterPoddyFree Member
I’m an LBS mechanic myself, pretty new to the game (Under 2 years) and as such I do odd servicing jobs for friends etc, as you do….
There’s one thing that gets to me, big time, about bike shops, and that’s bullshit and poor service. I don’t claim to know everything but the reason I’m doing what I do is because I love it, and because in the first place I was bullshitted to and overcharged. That’s THE reason I started doing my own mechanising some 20-odd years ago.
I’ve been on the customer side for a long time, and as such I have this odd thing – A conscience. I simply cannot sell someone a part or a service they don’t need, and I do not bodge. I always ask myself what I would do to my own bike, because I treat my own bikes very well indeed. That’s how I proceed, that’s how I operate.Anyway, to the point… One of my mates has a couple of Giants, and a certain LBS supplied and (I believe) at some point serviced them. They’ve had plenty of money off him. Thousands, certainly.
Last year their mechanic too him he needed a new FIT cartridge in his forks.
His forks are not FIT forks, just normal Floats.
He came back to me last night for a service on his XTC 29er. He’d been having some trouble putting new pads in his Elixirs, it’s the normal over-filled Avid issue….. Apparently the mechanic had told him that the brakes needed to be bled (fair enough, maybe) and that because they were feeling a bit soft at the lever that they needed a seal kit fitting.
There’s nothing wrong with them. I popped the new pads in and let a bit of fluid out of the calliper. Sorted. OK, maybe charge for a bleed, I get that, I really do, but FFS don’t try to scare someone into spending more money. They must be ****ing desperate for trade is all I can imagine.I’ve got absolutely no qualms at all naming the store – It’s the Giant Store in Guildford.
If anyone knows their mechanic, please tell him that there’s a bloke not far away doing him out of business because his customers don’t believe his bullshit.Rant over.
thisisnotaspoonFree MemberDidn’t Avid have an issue with seals swelling at some point? Someone on here posted a pic of an almost solid ‘bladder’ that had expanded.
Maybe he’d seen it before and wasn’t prepared to bleed a set of avids, not cure the problem, have ot replace the seals, tell the customer it was going to cost more, potentialy just be told to ‘stuff it I can get deore for £30 an end on CRC they’re not worth fixing’, and bleed them again? Or just tell the cutomer upfront the worst case.
That and I hate bleeding avids, I’d have told him they’d been contaminated by depleted unobtanium from the ranges and had to be destroyed.
Less defendable, but maybe an ‘MUST’ have the FIT cartrige for the performance, rather than ‘your old ones buggered’, and your friend missunderstood him.
PeterPoddyFree MemberNahh. No misunderstanding at all.*
It’s a faff, but I can do it blindfold now. That’s my job.
*EDIT,
Actually, forgive me, re-reading it, it looks like they told him his fork was knackered and that a FIT upgrade was the best fix at £300. It was a while back….!
Which was BS as I find ’em with a simple service
http://singletrackworld.com/forum/topic/foix-fit-damper-service-as-hard-as-it-looksTrying to rip people off. No getting away from it.
deadkennyFree MemberA lot of shops will do a quick analysis and without really knowing your bike’s quirks or even knowing the symptoms as people just say “service it”, they will just dive into an assumption, “oh you need XYZ”. It’s just a quick solution and an easy charge.
Bleeding brakes for just about anything at all is one. Personally I hold the view that the majority of brakes actually don’t need bleeding and there is another issue or just a simple case of calibrating pistons.
It’s the same with cars though. I don’t trust half the things I’m told by garages about “you need XYZ doing”. At least with bikes I’ve got to the point where I understand pretty much everything on my bikes, know when it feels right and not, and over time learnt what actually needs doing to deal with whatever issue I have. I’m a bit OCD about getting it right and will double and triple check the manual for the component and make sure I use the exact amount of oil/fluid/whatever as specified, torqued to the exact spec, etc. I think a lot of shops just do it to whatever they’re used to for “a brake”, “a fork”, etc and forget torque, it’s just gorilla handed or finger tight and that will do.
RamseyNeilFree MemberYou sound like a wonderful person . If only other bikeshops could get people of your caliber , and a conscience as well , that’s virtually unheard of , and don’t bodge either I’m in awe .
fathomerFull MemberOne of my friends needed a new chainring, he won’t do it himself and lives to far away for me to do it.
He took it into his new LBS as he’d moved recently and they told him he needed to replace his cassette and chain, which had been fitted 3 weeks before by his old LBS and that he needed to replace the other two rings as well.
He declined and he’s still using the same kit over a year later, safe to say he hasn’t been back since!
RamseyNeilFree MemberYes but surely people are capable of conversing with the mechanic in the shop . That conversation would normally go something along the lines of ” if I fit a new chainring it may not work with your other transmission components and we won’t know until we test ride it” at which point the customer would normally say ” I’m pretty sure it will be OK the chain was only fitted 3 weeks ago ” At which point the mechanic will say ” OK I’ll just put the new chainring on for you and all should be good “.
dobiejessmoFree MemberIts the way of the world if people can make money out of shafting others they will.My advice is to learn more about what you ride.No different in the motorcycle industry or cars.Not always possible I know.Know off some right cons over the years to do with Motorcycles.
Someone had an Honda XR250 years back and they charged them £100 for an oil change and oil filter.Parts at the time £10.Some shops are great.I always go to the small ones which are ACE.
JunkyardFree MemberYes Neil every single person who takes a bike into a shop knows exactly everything about it and how to fix it why else would it be in the shop in the hands of the mechanic?
The same is true of everything else where you ask an expert to do something…you know as much as they do it is just that you cannot be arsed to do it.
I dont always agree with PP on stuff on here but he knows his Bike stuff, has done some handy guides and he talks sense on this issue and shows he is both honest and wise. 2- 0 v you then
bencooperFree MemberYes but surely people are capable of conversing with the mechanic in the shop
That would be lovely. People vary a lot – I see a full range from people who know as much as me about bike mechanicing to people who need several goes to tell me how many wheels it’s got.
hilldodgerFree MemberI use their sister shop near Woking and by contrast their mechanic is a top bloke, I’ll pop in on Saturday and have a word – the manager does both stores so the message will get back
RorschachFree MemberI continually get bollocked by my boss for saving customers money by doing the right thing by them instead of fleecing them blind.
Some people just see labour/repairs as an easy way to claw back margin they have ‘lost’ by having to discount.deanfbmFree MemberWhen i was a mechanic, if i was presented a bike with avid brakes and if there was any hint of corrosion around the pistons or sluggishness/stickiness in said pistons accompanied with a request from the customer to “bleed the brakes because they’re not right”, i’d immediately ring customer and suggest that without a rebuild with new seals, the brakes would never function right, therefore costing more in workshop time faffing trying to get them to work ok rather than just doing a rebuild which would get them spot on first time.
Went through the rigour of unsuccessfully reviving avid brakes without a rebuild too many times to ever bother again.
When we were trained by sram tech we were even told the seals are only expected to last a year or so due to the dot fluid.
Your friends brakes might be really new and in really good condition, what i said above could be rubbish in this instance.
Though, “overfilled” is that really a thing? Unless the brakes have been bled previously without the pistons fully retracted, more fluid can’t jump in there during use, it’ll be air, therefore needing a bleed.
davidtaylforthFree MemberIf you aren’t able to service a bike yourself, you deserve ripping off. It’s really very simple stuff.
CaptainFlashheartFree MemberIf you aren’t able to service a bike yourself, you deserve ripping off. It’s really very simple stuff.
Obvious troll is obvious.
Servicing a bike takes one of two things – Time or money. If you have the time, it costs little money. If you have the money, you can buy someone else’s time.
I’m taking one of my bikes in to the LBS for a service on Saturday. I also have a fully equipped workshop at home, and can happily fix it all myself. So, why pay for someone else to do it? I’m busy. Oh, and I know I’m not being ripped off. So, stick that in your pipe, etc.
granny_ringFull Memberto people who need several goes to tell me how many wheels it’s got
LOL
JamieFree MemberSo, why pay for someone else to do it?
Well, given the amount you bang on about your LBS, I can only assume you have a crush on the mechanic 8)
JunkyardFree Memberpeople who need several goes to tell me how many wheels it’s got.
Fixing no voters bikes again 😉
Well played Jamie
JamieFree MemberI do like a bit of ginge now and again.
I always wondered what the ‘special grease’ was for…
breadcrumbFull MemberWhen we were trained by sram tech we were even told the seals are only expected to last a year or so due to the dot fluid.
My Juicys are 6 years old, never bled and are fine.
Same Juicys were a little over filled, I had to let a little out when I first replaced the pads.
Glad you’re not my mechanic!
RorschachFree MemberGlad you’re not mine!
Overfilled 😀
You kids make me chuckle.Anna-BFree MemberServicing a bike takes one of two things – Time or money. If you have the time, it costs little money. If you have the money, you can buy someone else’s time.
Three things, cos you need knowledge as well. I have no time, no money and no knowledge either. I do know PP though 🙂
And I have been in my LBS to get brakes (Avid) adjusted and been informed that the pads (£17) needed changing so we did them, when I know full well they didn’t need changing. These days I have Shimano and it’s all so simple. Make that 4 things CFH – easily fettled components!
CaptainFlashheartFree MemberThree things, cos you need knowledge as well
I had that filed under “Time” as in if you have the time to learn, you can. But otherwise, yes!
Grease, Jamie? Luxury.
honourablegeorgeFull Memberdeanfbm – Member
DOT fluid absorbs water from the air.
JamieFree MemberPoor mechanic does not even get Lube
Another victim to friction.
DAMN YOU PHYSICS!
*shakes fist at the sky*
teamhurtmoreFree MemberFrom a rough knowledge of where you live I guessed the shop immediately. They do have a problem.
robdobFree MemberThe thing is that you don’t need to BS customers to get extra sales. Good knowledge backed up with honesty will get customers coming back again and again. Making things more expensive for no reason is just wrong.
I think it’s unfair to expect everyone to fix their own bikes – cars are easier to fix and they require less specialist tools for the common service jobs but not many people fix their own cars.
yourguitarheroFree MemberCars are not easier to fix than bikes. That’s crazy.
They are heavy, far more complicated, filthy, rusty and it’s a pain in the ass to reach anything.norbert-colonFull MemberIt’s a shame, but not surprising that this sort of thing happens. I used to own an expensive (well it cost me a small fortune anyway) sports car and I lost track of the number of times the main stealer tried to rip me off at service time;
1) you need new brake pads, they’re getting low (no they weren’t)
2) Your disks are corroded, they need replacing (they were still fine at MOT time 12 months later)
3) You need new rear tyres and we can’t get the same ones anymore, so we’d better replace all 4 even though the front ones are only 25% worn (suitable tyres found within one phone call to a local tyre co.)
4) Oh and my particular favourite… your tracking is out, so we are going to need to use our expensive laser 4 wheel alignment thingamajig………….Kerching..
I only survived the experience with my wallet (semi) intact, because I got myself educated, so that I could sniff out the bullshite. I’d hate to think how many folks with more money than sense got absolutely shafted by this sort of thing over the years.
Good service is all about not leaving a nasty taste in somebody’s mouth. (ooer) If they are happy, they’ll come back again and again and will consider buying a particular brand as they know they’ll get good service with it. It’s amazing how many folk think that making a fast buck at the expense of customer satisfaction is acceptable business practice though.
bencooperFree MemberCars are not easier to fix than bikes. That’s crazy.
They are heavy, far more complicated, filthy, rusty and it’s a pain in the ass to reach anything.But they don’t really have compatability problems, most of them is quite low quality engineering so you can hit it with hammers or bodge it where it’s unseen, and modern cars aren’t really “fixed”, they just have parts swapped out.
I’ve fixed cars quite a bit – I pefer fixing bikes, but they’re different to work on, not harder or easier.
hilldodgerFree MemberMet one of the blokes from sister shop on a ride last night – was asked if it was that “stumpy little **** with the holes in his ears kicking off again”
LOL, guess you guys have previous ??ndthorntonFree MemberAfter a broken Cam belt earlier this year I think I can say with some confidence “bikes are a piece of piss”
trail_ratFree Member“cars are easier to fix and they require less specialist tools for the common service jobs but not many people fix their own cars.”
cars are a necessity for most folk and they like to pay for the reliability of having it garage serviced and repaired….
i guess by service jobs you mean – changing oil , fluids adn filters and maybe changing the brake pads…….in which case – havnt worked on many modern cars have you ….. some want a computer to wind back the hand brake – even 15 years ago some needed a special tool to wind them back…..
i like my drum brakes – easy as pie 😀
robdobFree MemberMet one of the blokes from sister shop on a ride last night – was asked if it was that “stumpy little **** with the holes in his ears kicking off again”
LOL, guess you guys have previous ??I bet that they wouldn’t dare say that to my brother (peterpoddy) face to face.
People just don’t like their dishonesty being revealed, do they?
JamieFree MemberPeople just don’t like their dishonesty being revealed, do they?
Didn’t your brother already backtrack from the accusations made in the OP, tho?
i.e The forks situation didn’t go down exactly as stated.
Also, others have stated that the remedy for the brakes, while maybe OTT/Pricey, is not unheard of.
The topic ‘LBS issues…. Grrrr….’ is closed to new replies.
