nicholas_yiu – Member
Well, I have been using my 27.2 KS Lev and the inner cable has snapped (This is a common problem with Lev I believe)
I tried replacing the inner cable but it does not seem to come apart the same way as the bigger diameter version. I ended up unthreading the “air rod” from the piston by mistake. It has now lost all pressure and still doesn’t come apart for cable replacement.
I have contacted KS to get it repaired (probably at my own cost) and ordered a new Hilo (shouldn’t have sold it in the first place!)
The KS will be up for sale when it comes back from repair. (probably for quite a low price) That inner cable is a design weak point for the post. It’s not so much of a problem for the bigger diameter ones as it’s easily replaceable. However, seeing that you probably have to send it back every time the inner cable snap on the 27.2, I think the simpler Hilo is a better option.
You mean the cable cable??? You couldn’t change the cable?
