it seemed like a go...
[Closed] it seemed like a good idea, superglue
 mrmo
[#2540476]
Noticed the front of the sole on my sidis has come away a bit, i thought a bit of superglue would solve that.
Found the super glue but couldn't get the top off, you would have thought they would come up with a better top for something designed to stick everything together?
Anyway got a pair of scissors and cut the bottom of the tube off. unsurprisingly i now have superglue all over my hands.
Are there any ways of removing the glue before i do something stupid. like hit the wrong key on this keyboard?
Posted : 07/03/2011 10:50 pm
very hot water
Posted : 07/03/2011 10:51 pm
Soap and water.
runb your hands to gether very slowly 😉
keep hands apart and let it dry nail varnish remover get it off some substance does but i have forgotten what- try google
Posted : 07/03/2011 10:52 pm
Have you got anything course and wiry within reach that you can grab? That should help.
Posted : 07/03/2011 10:56 pm
 Pook
Put more on and lick it. The combination of glue and saliva is a great adhesive remover bizarrely 😉
Posted : 07/03/2011 10:59 pm
i use the stuff near enough everyday in window fitting. i use warm water and soap and a pumice stone.
Superglue wont last long on the shoes though as water breaks it down even when dry.
Posted : 07/03/2011 11:01 pm
 kevj
Nail varnish remover will do the trick.
Posted : 07/03/2011 11:05 pm
First go for a pee and use both hands 😀
Posted : 07/03/2011 11:07 pm
Just dont scratch your arse
Posted : 07/03/2011 11:12 pm
I once used it to mend a sliced thumb as I'd heard that the SAS always carry it for fixing wounds. Don't try it... It's the second most painful thing in the world.
And when I went for a slash - about half an hour later - I glued myself to myself, intimately.
Separating a superglued thumb/cock is the most painful thing in the world. Fact.
Posted : 07/03/2011 11:14 pm
nail varnish remover, its what they use in hospital, no pain so its a good method!
Posted : 07/03/2011 11:16 pm
The only thing Superglue is good for is gluing skin together. It's what it was designed for originally.
Posted : 07/03/2011 11:23 pm
facepalm...
Posted : 07/03/2011 11:25 pm
No it wasn't.
We use but it's not the same as the household stuff and you don't put it in the wound.
Posted : 07/03/2011 11:27 pm
Grab your tool and a porn video and jump out the window on to the roof.
Posted : 07/03/2011 11:28 pm
it's acetone I think you'll find that does the job in nail varnish remover.
Posted : 07/03/2011 11:30 pm
IIRC superglue is catalysed by water, so not best to wet it.
Posted : 07/03/2011 11:31 pm
No it wasn't.
OK, not the brand superglue, but it's active ingredient was originally developed for the medical industry to glue skin during surgery.
Posted : 07/03/2011 11:41 pm
Apparently not as it wasn't approved for its use until '98. Though it was used in wars.
Posted : 07/03/2011 11:56 pm
Cyanoacrylate adhesive is what's used in surgery, and also in forensics for showing up latent fingerprints. I use superglue all the time for sealing cuts on my fingers. I handle large quantities of paper all day and it dries the skin out causing painful splits, and paper cuts. Indispensable stuff, dab it on and blow on it to dry, job done. And by comparison to the pussy up there ^^, it doesn't sting anywhere as much as the splits and cuts do, especially if you get positive plate developer in them. That I can personally attest to.
Posted : 07/03/2011 11:58 pm
touch a cow.
Posted : 08/03/2011 12:00 am
Burn it off. :mrgreen:
Posted : 08/03/2011 12:01 am
It wasn't.
Hot soapy water gets rid of it easily.
Posted : 08/03/2011 12:02 am
Only thing I ever find gets it off is soaking my hands until the skin falls off 🙂 Or chew it off.
Posted : 08/03/2011 12:07 am
tony24 - Member
Hmmm, so you use superglue on windows exposed to the elements, rain (water) being one of them, I bet you have a 10 year guarantee as well 😉
Sorry 😉
Posted : 08/03/2011 12:58 am
Hot soapy water, a handful of sugar will work as an abrasive, repeat, don't touch anything valuable
Posted : 08/03/2011 1:25 am
