Hi Chaps,
The shifting on my Mojo SL has never been quite right. It feels as if the indexing is out by a very small amount for either up on down – i.e. if you get down shifting indexed perfectly, then upshifting is out.
I’ve replaced all outer cables, and played around with routing, and length of outer to use on each section. There *should* be no additional compression occurring in the outer to throw it out, the outer ends aren’t frayed, the inners have been replaced a few times, and I’ve tried a new hanger.
Everything is matched well – i.e. Sram x0 10sp mech and shifter, the freehub isn’t sitting proud of the hub, the cassette isn’t missing a spacer.
B-screw and limit screws are set up fine too.
The only things I can think of are: bent rear mech (but it looks straight), worn cassette or jockey wheels (chain is about 0.7, jockey wheels look fine), tolerances in the rear stays being slightly out, cable routing being pants and actually causing some line compression.
My only next thought is to try some Alligator I-links, to see if I can remove any compression that’s occuring.
anyone else have any ideas?
Ricks
