I thought slacker w...
[Closed] I thought slacker was better?
[#2783988]
I thought the generally accepted wisdom is that slacker is better, especially on technical downhill stuff?
Just got back from 5 fab days riding with Doug at BasqueMTB and after a couple of days of using my Prophet at the super slack 67.5 degree FR setting, I thought I'd give the 69 degree head angle XC setting a go, at the time it was mostly to make the most of the technical climbing, which I was struggling with. To be honest I thought at the top of the first hill I'd be flipping back to FR for the descents, but to my surprise I found the steeper angles better both up and down, and the extra peddle clearance an added bonus for the signature Basque contoured singletrack.
So was it just a case of me getting my "eye in" on the third day, or is there anyone else who finds the idea that there is such a thing as "too slack"?
Posted : 24/05/2011 11:06 am
define 'better'
Posted : 24/05/2011 11:10 am
 GW
Sounds like you simply don't understand bike geometry all that well, there's way more to handling than just the H/A. I wouldn't worry about it and ride your bike whichever way you like it set-up.
Posted : 24/05/2011 11:13 am
67.5 isn't slack, let alone 'super slack'.
Sounds like you just weren't use to the different handling the slightly slacker geometry gave you.
Once you get used to it, I find slacker is most definitely better for steeper stuff.
Posted : 24/05/2011 11:17 am
Indeed, I've a DMR switchback in the garrage, proper old skool 'long travel' hardtail geometry, nothing beats it for being able to turn into corners and manouver about the trail quickly.
Slack is good when your going at mach3, but in tight, techy stuff steep may well be better.
Posted : 24/05/2011 11:45 am
There's just a widely spread view that slacker is better - no account seems to be taken for either the kind of riding that most people do, or the fact that mountain bike designers might actually know what they are talking about in the first place! I can't see why anyone wold want a bike that is reluctant to turn - provided it doesn't dart around all over the place like a crit bike - if you can ride it no handed fairly easily, it's slack enough in my book.
Posted : 24/05/2011 11:51 am
[b]thisisnotaspoon[/b] thanks your answer makes sense, it was generally slower speed but steep technical stuff. I can see on a Les Gets highway downhill the slack angle would be "better".
[b]doof_doof[/b] sorry I cut and paste from the cannondale marketing speil, my mistake 🙂
[b]GW[/b] I'm sure there is loads more to bike geometry (i'm no bike designer), but in this case the only thing I changed was the head angle.
Posted : 24/05/2011 11:52 am
 GW
is that "Glen's big book of utter twaddle"? 😆
Posted : 24/05/2011 11:55 am
Steepening the head angle on a given frame will also shorten the wheelbase. And depending on how it's done, as you said, it'll also change the BB height. So you didn't 'just' change the head angle.
Posted : 24/05/2011 11:56 am
What?
I'm not surprised the OP found he liked the way the bike handled on the normal side of slack. A bike that is easy to flick about is a pleasure to ride. Gotta go way back to the 80's to find bikes that were a liability, steering-speed-wise.
Posted : 24/05/2011 11:58 am
[i] but to my surprise I found the steeper angles better both up and down, and the extra peddle clearance an added bonus for the signature Basque contoured singletrack.
[/i]
[i] I'm sure there is loads more to bike geometry (i'm no bike designer), but in this case the only thing I changed was the head angle[/i]
These are contradictory sentences.
Posted : 24/05/2011 12:01 pm
Changing the head angle by lowering the rear end (which I assume you did) is one thing, changing it by winding out the forks is another.
Think about where you sit on the bike and where you want to put your weight for the kind of riding you are doing.
Slacker is far from always better, otherwise why wouldn't everyone be riding around with 66 degree HAs? Comparing a 5 and a Patriot is interesting - climbing is better on the 5 with a steeper HA but descending super steep stuff is worse. HA is linked to all sorts of things - wheelbase and cockpit reach for starters.
Posted : 24/05/2011 12:06 pm
Its not necessarily better, its just a trend brought over from the dh side of the sport (which appears to be made up of alot of mongs who just tend to follow exactly what the pros are doing)
Posted : 24/05/2011 12:09 pm
 GW
handy - if i were to change the HA by 1.5deg on any of my bikes I'd also be changing the bar/controls height/angle.. possibly even stem length.
DT - I think the term for the mongs you refer to is "fanboys". (but "alot" are fast as **** mongs)
Posted : 24/05/2011 12:18 pm
Personnaly I couldn't have had a different experience with my Prophet*, I tried the XC setting, found it to be riding a long travel XC bike, off-hand fast(ish) up and nervous down, basically too much travel to be good at anything.
Once in I put it into FR setting,the downs were so much more fun and handling very confidence inspiring. The FR setting may not be quite as good with long haul climbs ("so what?" in my book), but steep technical stuff is a doddle as (my) the balance is better with the slacker handling.
Just goes to show, how two ppl impression of the same bike can be so different, eh?
*I don't believe the Prophet to be super slack, I tried a 2010 Orange (briefly on the road) and thought that very slack, to the point of being more a 'problem' than a recommendation (for XC riding).
Posted : 24/05/2011 12:34 pm
That's one reason why some fork lockouts are annoying for riding on roads. They lock the fork at full extension, so you lose the sag and all of a sudden you're sitting up more, which is/feels slower for hacking along roads.
Posted : 24/05/2011 12:46 pm
Yeh, your not wrong. But they just seem to follow the crowd/fashions a bit too much.
Posted : 24/05/2011 1:00 pm
And the XC / Road / CX crowd don't... 🙄
Half the stuff on this site is either people jumping on the latest band wagon or trying to out niche each other.
Posted : 24/05/2011 1:04 pm
I am a slacker.... and I am betterer 😛
Posted : 24/05/2011 1:10 pm
Agreed! Marz ETA lock-down was (is?) great for not doing that. if only the top-out was less crude.
Posted : 24/05/2011 1:11 pm
I have adjustable dropouts on my frame which will affect the HA, chainstay length and BB height.
When I first built up the bike I always used the steepest setting because as you mentioned slacking it up will lower the BB which will result in more banging of pedals. However I did enjoy the slacker setting whenever riding something where pedal clearance was not an issue..
So what is the solution? Can't have it all?
I have a Lyrik fork, and it was the solo air model. To keep it sensitive I was running pretty low air pressure. This made it sensitive, but also kept it running pretty deep in it's travel. When the fork is low in it's travel it means the BB is lower resulting in hitting pedals more... I added some more air and things improved, but the fork lost it's sensitivity to small stuff.
Finally I changed the air spring for a coil spring, got the best of all worlds and as a result I can use a slacker setting and bang my pedals less then I used to on the steeper setting. Now I have 66 HA and still climb technical stuff (a lot of this stuff I could not clear with my old trail bikes that had 68HA) just fine.
A lot of changes affect other things too, you need to see the big picture. I'd prefer wider bars but can't do it due to riding a lot of paths with tight tree's. You need to pick what works for you, and see if you can find solutions to what you want and can't achieve.
Posted : 24/05/2011 1:16 pm
GW - what exactly is your problem?
Posted : 24/05/2011 1:31 pm
 GW
I have many, nothing you'll be able to help me solve, but thanks for asking.
Posted : 24/05/2011 3:37 pm
No different to anyone else then - except most people don't take every opportunity to be rude to another person for no reason. Is it some sort of on-line tourette's that is reserved just for me?
Posted : 24/05/2011 3:42 pm
 GW
no, anyone who talks shite is fair game IMO
Posted : 24/05/2011 3:44 pm
What, the "shite" I said that several other people repeated in their own way?
You just rail up every time I say something which which you disagree. And you are a rude **** with it. Maybe you just think you're funny. I know what I think.
Posted : 24/05/2011 3:51 pm
is it some sort of on-line tourette's
Don't feel special; he speaks to everyone like that.
Posted : 24/05/2011 4:00 pm
Oh no GW is a bit rude. Not suffering fools gladly I believe its known as.
He usually is right behind the rudeness tho.
Posted : 24/05/2011 4:02 pm
 GW
Really?
Who else was dumb enough to type this:
in their own way?
Simply stop talking shite and you won't be criticised.
Posted : 24/05/2011 4:04 pm
Kona magic link...?
Posted : 24/05/2011 4:08 pm
There is nothing dumb about that. A bike that you can take your hands off without fear of it flitting about (in the manner of a narrow tyred, steep angled 80's xc bike) has enough stability for most people's purposes. I fail to see why you even disagree with that, let alone declare it "shite".
That was just my way of saying that as long as it's not silly steep and twitchy it isn't necessarily wrong, and slacker (as the OP stated and you agreed) isn't necessarily better.
Posted : 24/05/2011 4:11 pm
 GW
Well why didn't you say that then?
What you did say was 100% dumb. eg. I can walk out right now and take my pick of any of 8-10 bikes, HA ranging from 74deg down to 63 and I can easily ride any one of them no handed.
You don't even seem to realise that what you call "reluctance to turn" in slacker bikes is because you don't actually turn them in the same manner as a steeper bike.
Posted : 24/05/2011 4:22 pm
Don't worry Glenp, its not just you, GW managed to deduce that I couldn't climb properly based on one comment I made about black chilli tyres climbing better than non-black chilli tyres, just accept he's better than everyone and move on... 8)
Posted : 24/05/2011 4:23 pm
Posted : 24/05/2011 4:26 pm
I knew what he meant....
Posted : 24/05/2011 4:28 pm
These bikes won't all be [u]equally[/u] as easy to ride no handed. Taking your hands off is a very good rule-of-thumb quick way to get a feel for bike stability. Stability which comes only partly from steep or slack-ness.
As for the second bit, I'm very tempted to say all sorts of things, but really - I don't have anything non-rude to say about that, so I won't say anything at all. Funny though.
Posted : 24/05/2011 4:29 pm
 GW
Awwww... molgrips... 'course you did 🙄
Posted : 24/05/2011 4:30 pm
Shrug.. believe what you wish to 🙂
Posted : 24/05/2011 4:32 pm
 Doug
One question nobody has asked the OP. What forks are you running? I've got 160mm Zocchies on mine, combine that with running quite a bit of sag on a 57mm stroke rear means that even in the XC setting the HA is probably slacker than a stock Prophet in the FR position.
ETA steepens everything up for the climbs so no probs there.
As for getting a slack bike to turn sharply, countersteer then fall into the turn.
Posted : 24/05/2011 4:34 pm
Most of what GW writes on here, regarding bikes n that, generally sounds about right to me.
Posted : 24/05/2011 4:35 pm
A Scandinavian Flick? You don't think having to do that may show the bike is 'too slack'?
Posted : 24/05/2011 7:16 pm
I used yo have a Fisher Cake, 5" travel 70 degree head angle. Climbed like a dream, great on singletrack but really scary on the very steep bits. Totally lacked confidence and didn't attempt much.
The 5 beats it hands down on anything going down hill.
Posted : 24/05/2011 7:33 pm
davidtaylforth - Member
Aye. ****ing horrible like, but correct.
Posted : 24/05/2011 8:31 pm
whinosp - Member
"As for getting a slack bike to turn sharply, countersteer then fall into the turn."
i think i know what he's talking about, counter-steering is a phrase used by motorbikists, in simple terms it means leaning the bike to steer, not turning the bars.
in more complicated terms, it means initiating a nice leaned-over turn by pushing with the 'wrong' hand - ie; pushing with your left hand to initiate a left turn, and vice versa.
it's hard (for me) to explain it better than that - maybe because i don't understand it, but i think i do, and this is STW...
Posted : 25/05/2011 10:15 am
