HTC Desire, Low dis...
[Closed] HTC Desire, Low disc space.
[#2568698]
As title.
I keep getting this notification on my HTC desire and it’s a real PITA.
I keep deleting apps and now hardly have any, had to remove some I was enjoying.
I know people on here have this phone and technical knowledge is plentiful so any help with combating this problem is kindly received.
Sorry if this has been done before but I couldn’t find anything through the search.
Thanks.
Posted : 16/03/2011 12:16 pm
search for "Apps to SD".
Various tools, apps and tricks to help you
http://www.androidtapp.com/tag/saving-android-apps-to-sd-card/
Posted : 16/03/2011 12:18 pm
Move all the apps you can to the SD card - enter in Settings, Applications, Manage applications. Then select "On SD card" at the top, and for any application unchecked select it and click on "Move to SD".
Edit: or do what Stoner suggests and download an app that'll do it for you, but first you might need to eliminate one of your current apps.
 fbk
Make sure you're running the lastest version of Android, then install ApptoSD. It will go through your apps and let you copy as many as possible over to your SD card, freeing up some space.
Posted : 16/03/2011 12:19 pm
Thanks. I do move as many as I can to SD but some don't let me move them? Will one of these apps move the ones that otherwise seem not able to move?
Posted : 16/03/2011 12:42 pm
Ohh can I resist?
Posted : 16/03/2011 1:18 pm
Ohh can I resist?
Posted : 16/03/2011 1:19 pm
Can I?
Get an iPhone
(Runs for cover)
Posted : 16/03/2011 1:20 pm
Have you got a lot of text messages stored? I ended up with several thousand and they all take up space on the internal memory.
I then backed them all up to GMail using SMS Backup+ before setting a limit for how many texts I could save from each person.
That made quite a large difference to the space...
Posted : 16/03/2011 1:24 pm
oh, can you move apps to SD cards on your iphone then M_F ?
Posted : 16/03/2011 1:25 pm
Would be an idea to find out what's taking up all the space. It's unlikely to be apps. MP3s? Videos?
Move some of them off the phone or get a bigger SD card.
Posted : 16/03/2011 1:26 pm
My internet browser cache was massive. Bearing in mind the on board memory isn't that big, deleting it made a big difference.
Posted : 16/03/2011 1:29 pm
Apps to SD won't move any apps that can't be. All you can do is wait until the app developers release an update that allows it to be moved.
Posted : 16/03/2011 1:30 pm
get an Iphone.....must not bite!
Cache cleared, SMS's limited (had alot!) and one or two apps I missed moved with help of App2SD and things are looking better.
I assumed all my music, pictures etc are stored on the SD card anyway?
I may be looking at a bigger or additional SD card anyway; any suggestions where to get a bargain?
Posted : 16/03/2011 1:43 pm
Rockplough - Member
If it's the same as the HTC desire I've used it has a pretty small partition for apps, either 256 or 512 mb.
Posted : 16/03/2011 1:45 pm
Root the phone using UnRevoked then you'll be able to move way more apps to the SD, even ones that A2SD on an unrooted phone can't shift. Search the XDA or Phandroid forum for the UnRevoked method, it's really easy.
Posted : 16/03/2011 1:51 pm
App2SD as others have said. There's a more permanent fix for this, but it's a bit of a hack. There's a -lot- of information and how-tos about this on the [url= http://androidforums.com/htc-desire/ ]Android Forums[/url], I'd suggest reading up on there.
For me, uninstalling the Flash and Facebook updates saved a massive amount of space.
Posted : 16/03/2011 1:52 pm
Don't need to - the phone seems to handle it's HD perfectly well.
Posted : 16/03/2011 1:58 pm
Just as well, as the iPhone doesn't have a removable SD. If you wanted to upgrade it, you'd had to have paid Apple another 100 quid for 15 quid's worth of storage at point of purchase.
To be fair, 16Gb's plenty for any sort of sensible use. Just, y'know, if we're all willy-waving there's pros and cons to both platforms.
Posted : 16/03/2011 2:07 pm
tw4t!!
Posted : 16/03/2011 2:10 pm
Yup there is and I was just being ****tish for lunchtime fun.
One thing I DO like about my iPhone, though, is that it can claim to be out of memory but still have a little bit left (like a reserve fuel tank) so I can take a picture/video and it will let me - then I can take it back to it's iTunes dock and permanently save it.
Posted : 16/03/2011 2:16 pm
Outrageous!
www.mobymemory.co.uk anyway.
Posted : 16/03/2011 2:30 pm
Apps to SD is all fine and dandy but not really a proper fix, that would be data to SD, it allows you to create a larger EXT4 partition (where your apps are stored when you download them) and eliminates the problems of moving the apps to the sdcard and loosing icons/links etc, it also makes I/O much quicker, check out the link below to a ROM that rocks 😉
http://forum.xda-developers.com/showthread.php?t=916417
Posted : 16/03/2011 3:51 pm
I know this. (-:
There are degress of 'fix' varying in complexity and fixedness. Best to start with the easiest rather than installing the SDK, rooting, de-branding, formatting, partitioning, flashing a custom ROM, etc etc, n'est-ce pas?
Posted : 16/03/2011 4:27 pm
That sounded negative, didn't it. I'm not disagreeing with you, Brake-neck, just that what you're suggesting is 'step 2,' not 'step 1.'
Posted : 16/03/2011 4:29 pm
No probs Cougar, get where ure coming from 😉
Posted : 17/03/2011 9:06 pm
