How do I set up a P...
[Closed] How do I set up a PS3 Media Server?
[#3597818]
How do I do it and what's a good setup? Am I right in thinking I need a 'NAS' drive with at least 1TB capacity?
Any advice gratefully received.
Posted : 23/01/2012 12:06 pm
You cannot setup the PS3 as the server. But it does have a DLNA Client built in so you can access media on a NAS.
Posted : 23/01/2012 12:23 pm
... or do you mean a media server that the PS3 can connect to?
Posted : 23/01/2012 12:25 pm
I know if you connect a HDD directly to the PS3 it neeeds to be formatted as FAT32, is that the same for a NAS drive?
Posted : 23/01/2012 12:32 pm
That's what I meant!
Posted : 23/01/2012 12:45 pm
If the NAS drive is connected to the network, rather than directly to the PS3 via USB, then it will not matter how it is formatted.
Posted : 23/01/2012 12:48 pm
If you have a PC with Windows on it, then Windows Media Player can act as a media server for your PS3. You can set it up using the Stream tab at the top of Media Player window. A DLNA NAS will do the trick nicely too, capacity is up to you really and the file format shouldn't matter.
Posted : 23/01/2012 1:10 pm
 dobo
A good place to start
http://www.ps3mediaserver.org/
Posted : 23/01/2012 9:27 pm
That, or [url= http://tversity.com/ ]TVersity[/url].
Posted : 23/01/2012 9:36 pm
Any PC running windows media player 11 can act as a server to a PS3
Plenty of guides on the net but it's very easy.
Posted : 23/01/2012 9:37 pm
Use TVersity don't infect your PC with WMP 11.
Posted : 23/01/2012 9:50 pm
