This was a brand new hub in 135 q/r form, purchased via CRC and built up into a 29er wheel by me.
After five months of use on a Trance 29er build I went to change the transmission which was very worn and chainsucking under pressure. I don’t keep a tally of mileage but I’d guess I have done between 1500 to 2000 miles on it.
Once the old cassette was off I noticed the free hub was stiff, so I opened it up to investigate and the two inner bearings inside the feehub had disintegrated scouring the axle in the process and leaving me with the outer bearing cases stuck inside the freehub.
For the last month of use I had noticed a creaking noise when putting a lot of pressure down on climbs, which I thought I had traced to the press fit bottom bracket cartridge and I’d bought a new one to fit when I did the chain/cassette/chainrings etc.
In hindsight (always a great thing!!) the noise must have been these disintegrating free hub bearings.
I’ve done a quick search on here and not found any similar problems being aired.
Anyone else experienced this?
