The blower for the heater/air con thingy decided to pack up yesterday, albeit it did provide the odd bit of action if you like for about 20 seconds but would then cut out.
Any ideas where to start looking? I'm thinking it can't be a fuse because it was working sporadically although now it seems to have stopped altogether - but then again I have no idea about cars so could be wrong.
I will be getting a new car in the next few months anyway but would like to try and sort this out given out weather can get cold at times and I won't be able to clear the windscreen! 😆
It could be a loose connection at the fuse, switch or blower motor.
It could also be the switch or the motor itself.
Does it work on certain speeds or none at all?
Hi snaps
It doesn't work at all now. The heat is coming out if that makses sense but isn't being blown into the car.
