The decal or the fork ir_bandito? Can get more made if you want a decal. in regards to the Hefty fork, contact Tony.
Bikebouy I live in the south….it’s not very muddy down here, but a little flat. Tbh I was 5 mins into the ride and had stopped to tighten up the bolts etc as it was the first ride….big smiles, as it rides brilliantly. It climbs in a way I have only experienced back in the day when 1″ threaded headsets were all the rage and Orange still made all of their bikes in the UK, suspension at both ends was a pipe dream, and we all had an embarrassing relationship to dayglo Lycra.
Singlespeedstu the overall wheelbase is only a tiny bit shorter than the rigid Surly fork now, where as if you used the standard clamps I am fairly sure that the effective wheelbase would be longer than Surly intended. Also, the offset in the front wheel is really playing it safe. I have massive clearance as you can see in the pics, so if you wanted to do this kind of build I have been given some spoke lengths by the wheel builder, Bungle in Wareham, that would be less extreme, so the clamps wouldn’t need to be so far to the left. With the lock out activated, it rides really well, but with the Lefty working it soaks up everything and grips even more. it accelerates with an unnerving sense of being strapped to the outside of a 50 tonne truck falling off a very tall cliff. It’s awesome
